1. Re: Re-installing Adobe Premiere Elements 10
Ritzlore Nov 10, 2014 6:29 AM (in response to Ritzlore)After selecting to install the program and the English language, it says it's preparing the installer, then opens a window labelled windows installer. That's when the script comes up a follows:
Windows ® Installer. V 5.0.7601.17514
msiexec /Option <Required Parameter> [Optional Parameter]
Install Options
</package | /i> <Product.msi>
Installs or configures a product
/a <Product.msi>
Administrative install - Installs a product on the network
/j<u|m> <Product.msi> [/t <Transform List>] [/g <Language ID>]
Advertises a product - m to all users, u to current user
</uninstall | /x> <Product.msi | ProductCode>
Uninstalls the product
Display Options
/quiet
Quiet mode, no user interaction
/passive
Unattended mode - progress bar only
/q[n|b|r|f]
Sets user interface level
n - No UI
b - Basic UI
r - Reduced UI
f - Full UI (default)
/help
Help information
Restart Options
/norestart
Do not restart after the installation is complete
/promptrestart
Prompts the user for restart if necessary
/forcerestart
Always restart the computer after installation
Logging Options
/l[i|w|e|a|r|u|c|m|o|p|v|x|+|!|*] <LogFile>
i - Status messages
w - Nonfatal warnings
e - All error messages
a - Start up of actions
r - Action-specific records
u - User requests
c - Initial UI parameters
m - Out-of-memory or fatal exit information
o - Out-of-disk-space messages
p - Terminal properties
v - Verbose output
x - Extra debugging information
+ - Append to existing log file
! - Flush each line to the log
* - Log all information, except for v and x options
/log <LogFile>
Equivalent of /l* <LogFile>
Update Options
/update <Update1.msp>[;Update2.msp]
Applies update(s)
/uninstall <PatchCodeGuid>[;Update2.msp] /package <Product.msi | ProductCode>
Remove update(s) for a product
Repair Options
/f[p|e|c|m|s|o|d|a|u|v] <Product.msi | ProductCode>
Repairs a product
p - only if file is missing
o - if file is missing or an older version is installed (default)
e - if file is missing or an equal or older version is installed
d - if file is missing or a different version is installed
c - if file is missing or checksum does not match the calculated value
a - forces all files to be reinstalled
u - all required user-specific registry entries (default)
m - all required computer-specific registry entries (default)
s - all existing shortcuts (default)
v - runs from source and recaches local package
Setting Public Properties
[PROPERTY=PropertyValue]
Consult the Windows ® Installer SDK for additional documentation on the
command line syntax.
Copyright © Microsoft Corporation. All rights reserved.
Portions of this software are based in part on the work of the Independent JPEG Group.
2. Re: Re-installing Adobe Premiere Elements 10
A.T. Romano Nov 10, 2014 4:53 PM (in response to Ritzlore)Ritzlore
Please uninstall all traces of your Premiere Elements 10. After the uninstall the usual Control Panel way, do a free ccleaner run through to get rid of any leftovers from incomplete installs uninstalls. CCleaner - PC Optimization and Cleaning - Free Download
Then install the program with the antivirus and firewall(s) disabled.
But, instead of using your installation disc for the install, please consider the following...
Please download and install the free tryout of Premiere Elements 10 from the following web site and then insert your purchased serial number into it.
Please read and carry out carefully the web site's "Note: Very Important Instructions" in order to avoid any Access Denied message.
Photoshop Elements 10 Direct Download Links: Free Trials, Premiere | ProDesignTools
We will be watching for your results.
ATR
