thanks to the lrosenth for the help with my question about support for CID keyed Type1 fonts in PDF.
I will make sure that I read the ISO PDF spec - it is more clear.
Sadly, I have another question:
I have a valid CIDFont (consists of a readable PS part and also binary data which I believe is _parts_ of a CFF font program, not the whole program).
The readable PS part has info like byte offsets to CharStrings and also the table that maps CID values to font/glyph (CIDMap)
The FreeType library will render glyphs from this font.
The binary parts appear to be the CIDMap and CharStrings etc - but not the usual CFF header stuff - ie. just the bits you need.
My question: Am I right that you cant put such a CIDFont in a PDF file as an embedded font program (as part of a composite CIDFontType0) ?
From my reading of the spec, a composite font (Type0) in PDF references a CIDFont dict that doesn't have any of the info that the PS CIDFont contains (such as byte offsets to charstring data etc)
and so it needs the complete CFF program - specified as /FontFile3 in the font descriptor.
regards
JLM
You could try running it through Distiller and see what it does. Not as satisfying as finding the answer from study of the spec, but interesting nevertheless. If it is printable PostScript, Distiller must be able to do something with it.
