Show 2 replies
1. Re: I'm having problems with Text box resizing. I can only chage width or height not both
Rob Dillon Nov 11, 2014 1:05 PM (in response to s&b)If you have the textfield set to "Static Text", then the text space will extend vertically to contain the text that you type into it. You can adjust the width, and the height will change to fit the text that is contained.
If you change the textfield to "Input" or "Dynamic" then you will be able to size the textfield as you like.
2. Re: I'm having problems with Text box resizing. I can only chage width or height not both
s&b Nov 11, 2014 6:29 PM (in response to Rob Dillon)Thank you it worked.
Steve
