1. Re: Master Slide templates are not showing correctly once out of film view
Lilybiri Nov 11, 2014 8:41 AM (in response to AQthinks)The quizzing master slides are very special, don't try to delete any objects there because they all have some functionality. You can tweak, move things and when creating question slides from those master slides you'll have the opportunity to hide some buttons like Back (see Quiz Preferences), Clear.
The feedback captions (or shapes, if you choose for them in CP8.0.1): change the text in Quiz Preferences, Default Labels, not in the master slides.
As for your other problem, I never had that issue at all. My work flow is to first edit the Object Styles in the Object Style Manager, then to edit the Master slides, starting with the Main Master slide when appropriate. Do NOT edit the Blank slide (you can create a duplicate and edit that one) if you ever want to insert Software simulation slides. Maybe your idea of the master slides is not exactly what it is in Captivate? Themes consist of objects styles, master slides and skin and you have in version 8 also a the Theme Color palette that can be changed and/or customized.
Telling which version you are using is essential to get a correct answer. And if you are on CP8, please also tell if you are talking about a normal or a responsive project.
2. Re: Master Slide templates are not showing correctly once out of film view
AQthinks Nov 11, 2014 10:18 AM (in response to Lilybiri)Editing the default theme for the quiz objects, did solve the first problem. However editing objects in the Master Slide view, is still troublesome.
I clicked the option to remove the play bar through out the course, now the background theme does not extend to cover the entire slide.
3. Re: Master Slide templates are not showing correctly once out of film view
Lilybiri Nov 11, 2014 10:22 AM (in response to AQthinks)If you remove the playbar, you also have either to remove the borders in the Skin editor, or make the bottom border that has the height of the hidden playbar smaller.
I still don't understand your problems with editing master slides, and have never seen such a question (I'm on the forums daily). Which version do you use, PLEASE?
4. Re: Master Slide templates are not showing correctly once out of film view
AQthinks Nov 11, 2014 10:55 AM (in response to Lilybiri)I'm using Captivate CC
Here is an example of when the tool bar disappears. Exactly how do I resize the tool bar to account for when the bar is hidden? I have watched a full course on Lynda for captivate but it seems I am facing a rather steep learning curve. Do you have any suggestions on other tutorials?
5. Re: Master Slide templates are not showing correctly once out of film view
Lilybiri Nov 11, 2014 11:12 AM (in response to AQthinks)Hmmm, sorry about your frustration but as a daily user of Lynda.com for all kind of applications I find the Captivate courses much below their usual level. And I have commented that way on their site multiple times. There is no good practice, no explanation of proper workflows now about the logic of Captivate. You are not the first user that I helped out after such a 'bad' introduction. If you look at my answers, you'll see that I'm not that harsh usually. Having taught all kind of software applications since over 20 years, it is to me also very frustrating when I see this happening. And sorry, cannot help you with pointing to other tutorials, I never bought any book (had the same reflections when looking at books), nor trainings. I just learned by exploring and helping other users out.
Captivate is a very versatile tool, but learning curve is made unnecessary steep by bad approach in many tutorials. You'll learn recipes in them, nothing about the concept nor the logic. And once you want to change the recipe, you are stuck.
Do you know that in a theme you have theme color palette, object styles (did you ever use the Object Style Manager), master slides and a skin. The playbar is part of the skin. When you go to the skin editor, first tab allowed you to uncheck the playbar, go to the second tab 'Borders', and uncheck also the Borders.
Even terminology is a problem: what do you mean by a toolbar? There is for the moment in Captivate only a Big Button Bar in editing mode (Slides, Themes, Text, Shapes....). The real toolbar disappeared in CP8, was there in previous versions. There is an Align bar remaining, but it is not visible until you show it with the Window menu.
6. Re: Master Slide templates are not showing correctly once out of film view
AQthinks Nov 12, 2014 8:29 AM (in response to AQthinks)Morning Lilybiri,
So it turns out a lot of my problems had to do with not updating captivate. The play bar issue was solved with this : https://workspaces.acrobat.com/?d=wo37Ob7I-*v3IPc8UGHD*Q
which also helped with the a blank white screen being displayed before for first slide, It also solved the issue I was having with my buttons, none of them were working.
But thank you so much, knowing about the skin editor, object editor will help in the future. I don't understand how Lynda could leave out features such as those when those are some of the first things a designer will seek to make changes to for an individual look.
Thanks for being active in the forums.
7. Re: Master Slide templates are not showing correctly once out of film view
Lilybiri Nov 12, 2014 8:47 AM (in response to AQthinks)You're welcome, but here it is already evening
You understand my frustration about the Lynda course, to me explaining Timeline and Themes with all the components are basic concepts that should be tackled early in a training. And it happens almost never.
