Locked
Re: Adobe Flash Player 15.0 r0 Has Stopped Working
Nov 09, 2014 Nov 09, 2014
Thanks for your assistance  ... I will try any good suggestions you have. Please note the following:
  1. I really don't understand the previous information provided by "samclean"  ..... I did not submit an error report that generated those diagnosis.
  2. I get the same flash error when using Internet Explorer, so I'm not convinced that this is Firefox related.  I'm thinking that it's more likely an issue between Vista and Flash.
Thanks again for any help you can provide.
2.4K
Adobe Employee ,
Nov 10, 2014 Nov 10, 2014
I've branched this to a new discussion, since the issue you're experiencing sounds like it's unrelated to the thread you posted in.
Let's start over with some basic information about the problem you're seeing:
Read Before Posting: How To Get A Useful Answer To Your Question
Here's the original problem again  .....
Looking for a solution to this problem that started several weeks ago, after a recent Windows update and / or Flash Player update.  I'm having this problem on my HP laptop that runs Vista (32 bit).  I normally use Firefox, but the same thing happens in Internet Explorer. Anytime I attempt to run a video, I get this error message  ... "Adobe Flash Player 15.0 r0 Has Stopped Working ... a problem caused the program to stop working.  Windows will close the program  .... "
I have tried reinstalling the latest Flash Player version several times, and I have done the "CLEAN INSTALL" as suggested on this site.  But, so far, nothing has resolved this problem.
Adobe Employee ,
Please work through the following troubleshooting guide:
Video playback issues
If you're stil stuck, give me a rundown of what you did and the results, as well as the output of dxdiag.
Nov 11, 2014 Nov 11, 2014
I am able to play both videos in the link you sent, but I am still having a problems with most other videos.   See the below screen shots:
I tried disabling hardware acceleration, but there was no change to the problem.   Below is the output from the diagnostics tool:
System Information
Time of this report: 11/11/2014, 12:32:37
       Machine name: JRW_HP_LAPTOP
   Operating System: Windows Vista™ Home Premium (6.0, Build 6002) Service Pack 2 (6002.vistasp2_gdr.130707-1535)
           Language: English (Regional Setting: English)
System Manufacturer: Hewlett-Packard
       System Model: HP Pavilion dv3 Notebook PC
               BIOS: Default System BIOS
          Processor: Pentium(R) Dual-Core CPU       T4200  @ 2.00GHz (2 CPUs), ~2.0GHz
             Memory: 3002MB RAM
          Page File: 1933MB used, 4277MB available
        Windows Dir: C:\Windows
    DirectX Version: DirectX 11
DX Setup Parameters: Not found
     DxDiag Version: 7.00.6002.18107 32bit Unicode
DxDiag Notes
      Display Tab 1: No problems found.
        Sound Tab 1: No problems found.
        Sound Tab 2: No problems found.
          Input Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (retail)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
        Card name: Mobile Intel(R) 4 Series Express Chipset Family
     Manufacturer: Intel Corporation
        Chip type: Mobile Intel(R) 4 Series Express Chipset Family
         DAC type: Internal
       Device Key: Enum\PCI\VEN_8086&DEV_2A42&SUBSYS_306D103C&REV_07
   Display Memory: 1309 MB
Dedicated Memory: 64 MB
    Shared Memory: 1245 MB
     Current Mode: 1366 x 768 (32 bit) (59Hz)
          Monitor: Generic PnP Monitor
      Driver Name: igdumdx32.dll,igd10umd32.dll
   Driver Version: 7.15.0010.1591 (English)
      DDI Version: 10
   BGRA Supported: Yes
Driver Attributes: Final Retail
Driver Date/Size: 10/28/2008 02:25:44, 536576 bytes
      WHQL Logo'd: n/a
  WHQL Date Stamp: n/a
Device Identifier: {D7B78E66-6902-11CF-BB75-6710A7C2CA35}
        Vendor ID: 0x8086
        Device ID: 0x2A42
        SubSys ID: 0x306D103C
      Revision ID: 0x0007
      Revision ID: 0x0007
      Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_B ModeWMV9_C ModeVC1_B ModeVC1_C
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                   {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                   {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                   {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                   {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                   {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                   {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                   {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                   {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
     DDraw Status: Enabled
       D3D Status: Enabled
       AGP Status: Enabled
Sound Devices
            Description: Speakers and Headphones (IDT High Definition Audio CODEC)
Default Sound Playback: Yes
Default Voice Playback: Yes
            Hardware ID: HDAUDIO\FUNC_01&VEN_111D&DEV_7608&SUBSYS_103C306E&REV_1002
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            Driver Name: stwrt.sys
         Driver Version: 6.10.6146.0000 (English)
            WHQL Logo'd: n/a
          Date and Size: 1/28/2009 07:16:04, 394240 bytes
            Other Files:
        Driver Provider: IDT
         HW Accel Level: Basic
              Cap Flags: 0x0
    Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
              HW Memory: 0
       Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
   I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
            Description: Independent Headphones (IDT High Definition Audio CODEC)
Default Sound Playback: No
Default Voice Playback: No
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            WHQL Logo'd: n/a
            Other Files:
              Cap Flags: 0x0
              HW Memory: 0
Sound Capture Devices
            Description: Integrated Microphone Array (IDT High Definition Audio CODEC)
  Default Sound Capture: Yes
  Default Voice Capture: Yes
              Cap Flags: 0x0
           Format Flags: 0x0
            Description: Stereo Mix (IDT High Definition Audio CODEC)
  Default Sound Capture: No
  Default Voice Capture: No
              Cap Flags: 0x0
           Format Flags: 0x0
            Description: External Mic (IDT High Definition Audio CODEC)
              Cap Flags: 0x0
           Format Flags: 0x0
DirectInput Devices
      Device Name: Mouse
         Attached: 1
    Controller ID: n/a
Vendor/Product ID: n/a
        FF Driver: n/a
      Device Name: Keyboard
         Attached: 1
    Controller ID: n/a
        FF Driver: n/a
      Device Name: Microsoft eHome Infrared Transceiver
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x006D
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
      Device Name: Bluetooth Remote Control HID Device
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0xFFFE, 0xFFFE
        FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x2934
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 6/28/2013 20:07:15, 197632 bytes
| Driver: usbd.sys, 6/28/2013 20:06:53, 6016 bytes
Gameport Devices
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard with HP QLB
| Matching Device ID: *pnp0303
| Upper Filters: HpqKbFiltr
| Service: i8042prt
| Driver: HpqKbFiltr.sys, 6/18/2007 18:12:04, 16768 bytes
| Driver: wdfcoinstaller01005.dll, 11/2/2006 08:09:50, 1419232 bytes
| Driver: i8042prt.sys, 1/20/2008 20:23:20, 54784 bytes
| Driver: kbdclass.sys, 1/20/2008 20:23:23, 35384 bytes
+ Microsoft eHome Remote Control Keyboard keys
| Matching Device ID: hid\irdevice&col05
| Service: kbdhid
| Driver: kbdhid.sys, 4/10/2009 22:38:40, 17408 bytes
+ Microsoft eHome MCIR Keyboard
| Matching Device ID: hid\irdevice&col06
| Service: kbdhid
+ Microsoft eHome MCIR 109 Keyboard
| Matching Device ID: hid\irdevice&col07
| Service: kbdhid
| Driver: kbd106.dll, 1/20/2008 20:23:23, 6656 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
+ Synaptics PS/2 Port TouchPad
| Matching Device ID: *syn1e07
| Upper Filters: SynTP
| Service: i8042prt
+ HID-compliant mouse
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouhid.sys, 1/20/2008 20:23:20, 15872 bytes
| Driver: mouclass.sys, 1/20/2008 20:23:20, 34360 bytes
+ Logitech USB Wheel Mouse
| Vendor/Product ID: 0x046D, 0xC00E
| Matching Device ID: hid\vid_046d&pid_c00e
| Service: mouhid
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: termdd.sys, 4/11/2009 00:32:52, 53224 bytes
| Driver: sermouse.sys, 1/20/2008 20:23:20, 19968 bytes
Disk & DVD/CD-ROM Drives
      Drive: C:
Free Space: 130.9 GB
Total Space: 292.8 GB
File System: NTFS
      Model: SAMSUNG HM320JI ATA Device
      Drive: D:
Free Space: 2.0 GB
Total Space: 12.5 GB
File System: NTFS
      Drive: E:
      Model: Optiarc DVD RW AD-7581S ATA Device
     Driver: c:\windows\system32\drivers\cdrom.sys, 6.00.6002.18005 (English), 4/10/2009 22:39:17, 67072 bytes
System Devices
     Name: Intel(R) WiFi Link 5100 AGN
Device ID: PCI\VEN_8086&DEV_4237&SUBSYS_12118086&REV_00\4&23507F69&0&00E2
   Driver: n/a
     Name: Mobile Intel(R) 4 Series Express Chipset Family
Device ID: PCI\VEN_8086&DEV_2A43&SUBSYS_306D103C&REV_07\3&E89B380&0&11
   Driver: n/a
Device ID: PCI\VEN_8086&DEV_2A42&SUBSYS_306D103C&REV_07\3&E89B380&0&10
   Driver: C:\Windows\system32\DRIVERS\igdkmd32.sys, 7.15.0010.1591 (English), 10/28/2008 02:29:36, 2476544 bytes
   Driver: C:\Windows\system32\igdumd32.dll, 7.15.0010.1591 (English), 10/28/2008 02:29:40, 3411968 bytes
   Driver: C:\Windows\system32\igkrng500.bin, 10/28/2008 02:28:36, 2026604 bytes
   Driver: C:\Windows\system32\igcompkrng500.bin, 10/28/2008 02:28:36, 445796 bytes
   Driver: C:\Windows\system32\igfcg550.bin, 10/28/2008 02:28:36, 147172 bytes
   Driver: C:\Windows\system32\iglhxs32.vp, 10/28/2008 03:06:00, 36080 bytes
   Driver: C:\Windows\system32\iglhxo32.vp, 10/28/2008 01:58:40, 2096 bytes
   Driver: C:\Windows\system32\iglhxc32.vp, 10/28/2008 01:58:40, 2096 bytes
   Driver: C:\Windows\system32\hccutils.dll, 7.14.0010.1591 (English), 10/28/2008 02:04:28, 106496 bytes
   Driver: C:\Windows\system32\igfxsrvc.dll, 7.14.0010.1591 (English), 10/28/2008 02:04:50, 52224 bytes
   Driver: C:\Windows\system32\igfxsrvc.exe, 7.14.0010.1591 (English), 11/11/2008 05:11:44, 256536 bytes
   Driver: C:\Windows\system32\igfxpph.dll, 7.14.0010.1591 (English), 10/28/2008 02:05:08, 217088 bytes
   Driver: C:\Windows\system32\igfxcpl.cpl, 7.14.0010.1591 (English), 10/28/2008 02:05:00, 126976 bytes
   Driver: C:\Windows\system32\igfxcfg.exe, 7.14.0010.1591 (English), 11/11/2008 05:11:36, 670232 bytes
   Driver: C:\Windows\system32\igfxdev.dll, 7.14.0010.1591 (English), 10/28/2008 02:04:24, 221184 bytes
   Driver: C:\Windows\system32\igfxdo.dll, 7.14.0010.1591 (English), 10/28/2008 02:04:36, 135168 bytes
   Driver: C:\Windows\system32\igfxtray.exe, 7.14.0010.1591 (English), 11/11/2008 05:11:46, 150040 bytes
   Driver: C:\Windows\system32\hkcmd.exe, 7.14.0010.1591 (English), 11/11/2008 05:11:34, 178712 bytes
   Driver: C:\Windows\system32\igfxress.dll, 7.14.0010.1591 (English), 10/28/2008 02:04:12, 5672960 bytes
   Driver: C:\Windows\system32\igfxpers.exe, 7.14.0010.1591 (English), 11/11/2008 05:11:42, 154136 bytes
   Driver: C:\Windows\system32\igfxTMM.dll, 7.14.0010.1591 (English), 10/28/2008 02:05:32, 258048 bytes
   Driver: C:\Windows\system32\igfxext.exe, 7.14.0010.1591 (English), 11/11/2008 05:11:38, 178712 bytes
   Driver: C:\Windows\system32\igfxexps.dll, 7.14.0010.1591 (English), 10/28/2008 02:05:02, 24576 bytes
   Driver: C:\Windows\system32\oemdspif.dll, 7.14.0010.1591 (English), 10/28/2008 02:05:16, 69632 bytes
   Driver: C:\Windows\system32\igfxrara.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:06, 229376 bytes
   Driver: C:\Windows\system32\igfxrchs.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:06, 155648 bytes
   Driver: C:\Windows\system32\igfxrcht.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:06, 155648 bytes
   Driver: C:\Windows\system32\igfxrdan.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:06, 258048 bytes
   Driver: C:\Windows\system32\igfxrdeu.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:08, 278528 bytes
   Driver: C:\Windows\system32\igfxrenu.lrc, 7.14.0010.1591 (English), 10/28/2008 02:04:12, 249856 bytes
   Driver: C:\Windows\system32\igfxresp.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:08, 278528 bytes
   Driver: C:\Windows\system32\igfxrfin.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:08, 258048 bytes
   Driver: C:\Windows\system32\igfxrfra.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:08, 278528 bytes
   Driver: C:\Windows\system32\igfxrheb.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:10, 225280 bytes
   Driver: C:\Windows\system32\igfxrita.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:10, 278528 bytes
   Driver: C:\Windows\system32\igfxrjpn.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:10, 184320 bytes
   Driver: C:\Windows\system32\igfxrkor.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:12, 180224 bytes
   Driver: C:\Windows\system32\igfxrnld.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:12, 274432 bytes
   Driver: C:\Windows\system32\igfxrnor.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:12, 253952 bytes
   Driver: C:\Windows\system32\igfxrplk.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:12, 262144 bytes
   Driver: C:\Windows\system32\igfxrptb.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:14, 266240 bytes
   Driver: C:\Windows\system32\igfxrptg.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:14, 270336 bytes
   Driver: C:\Windows\system32\igfxrrus.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:14, 266240 bytes
   Driver: C:\Windows\system32\igfxrsky.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:14, 258048 bytes
   Driver: C:\Windows\system32\igfxrslv.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:16, 253952 bytes
   Driver: C:\Windows\system32\igfxrsve.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:16, 258048 bytes
   Driver: C:\Windows\system32\igfxrtha.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:16, 237568 bytes
   Driver: C:\Windows\system32\igfxrcsy.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:06, 258048 bytes
   Driver: C:\Windows\system32\igfxrell.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:08, 286720 bytes
   Driver: C:\Windows\system32\igfxrhun.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:10, 262144 bytes
   Driver: C:\Windows\system32\igfxrtrk.lrc, 7.14.0010.1591 (English), 10/28/2008 02:08:16, 253952 bytes
   Driver: C:\Windows\system32\ig4icd32.dll, 7.15.0010.1591 (English), 10/28/2008 02:14:34, 3895296 bytes
   Driver: C:\Windows\system32\ig4dev32.dll, 7.15.0010.1591 (English), 10/28/2008 02:14:44, 2359296 bytes
   Driver: C:\Windows\system32\igd10umd32.dll, 7.15.0010.1591 (English), 10/28/2008 02:21:36, 2256896 bytes
   Driver: C:\Windows\system32\igdumdx32.dll, 7.15.0010.1591 (English), 10/28/2008 02:25:44, 536576 bytes
   Driver: C:\Windows\system32\igfxCoIn_v1591.dll, 10/28/2008 02:35:26, 147456 bytes
     Name: Mobile Intel(R) 4 Series Chipset Processor to DRAM Controller - 2A40
Device ID: PCI\VEN_8086&DEV_2A40&SUBSYS_306D103C&REV_07\3&E89B380&0&00
   Driver: n/a
     Name: Intel(R) ICH9 Family PCI Express Root Port 6 - 294A
Device ID: PCI\VEN_8086&DEV_294A&SUBSYS_306D103C&REV_03\3&E89B380&0&E5
   Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.00.6002.18005 (English), 4/11/2009 00:32:55, 149480 bytes
     Name: Intel(R) ICH9 Family PCI Express Root Port 4 - 2946
Device ID: PCI\VEN_8086&DEV_2946&SUBSYS_306D103C&REV_03\3&E89B380&0&E3
     Name: Intel(R) ICH9 Family PCI Express Root Port 3 - 2944
Device ID: PCI\VEN_8086&DEV_2944&SUBSYS_306D103C&REV_03\3&E89B380&0&E2
     Name: Intel(R) ICH9 Family PCI Express Root Port 1 - 2940
Device ID: PCI\VEN_8086&DEV_2940&SUBSYS_306D103C&REV_03\3&E89B380&0&E0
     Name: High Definition Audio Controller
Device ID: PCI\VEN_8086&DEV_293E&SUBSYS_306D103C&REV_03\3&E89B380&0&D8
   Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.00.6002.18005 (English), 4/10/2009 22:42:42, 561152 bytes
     Name: Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293C
Device ID: PCI\VEN_8086&DEV_293C&SUBSYS_306D103C&REV_03\3&E89B380&0&D7
   Driver: C:\Windows\system32\drivers\usbehci.sys, 6.00.6002.18465 (English), 5/5/2011 07:54:07, 39936 bytes
   Driver: C:\Windows\system32\drivers\usbport.sys, 6.00.6002.18875 (English), 6/28/2013 20:07:01, 226304 bytes
   Driver: C:\Windows\system32\drivers\usbhub.sys, 6.00.6002.18875 (English), 6/28/2013 20:07:15, 197632 bytes
   Driver: C:\Windows\system32\hccoin.dll, 6.00.6002.18465 (English), 5/5/2011 10:01:28, 8704 bytes
   Driver: C:\Windows\system32\hcrstco.dll, 6.00.6002.18465 (English), 5/5/2011 10:01:28, 15872 bytes
     Name: Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293A
Device ID: PCI\VEN_8086&DEV_293A&SUBSYS_306D103C&REV_03\3&E89B380&0&EF
     Name: Intel(R) ICH9 Family USB Universal Host Controller - 2938
Device ID: PCI\VEN_8086&DEV_2938&SUBSYS_306D103C&REV_03\3&E89B380&0&D1
   Driver: C:\Windows\system32\drivers\usbuhci.sys, 6.00.6002.18465 (English), 5/5/2011 07:54:07, 23552 bytes
     Name: Intel(R) ICH9 Family USB Universal Host Controller - 2937
Device ID: PCI\VEN_8086&DEV_2937&SUBSYS_306D103C&REV_03\3&E89B380&0&D0
     Name: Intel(R) ICH9 Family USB Universal Host Controller - 2936
Device ID: PCI\VEN_8086&DEV_2936&SUBSYS_306D103C&REV_03\3&E89B380&0&EA
     Name: Intel(R) ICH9 Family USB Universal Host Controller - 2935
Device ID: PCI\VEN_8086&DEV_2935&SUBSYS_306D103C&REV_03\3&E89B380&0&E9
     Name: Intel(R) ICH9 Family USB Universal Host Controller - 2934
Device ID: PCI\VEN_8086&DEV_2934&SUBSYS_306D103C&REV_03\3&E89B380&0&E8
     Name: Intel(R) ICH9 Family SMBus Controller - 2930
Device ID: PCI\VEN_8086&DEV_2930&SUBSYS_306D103C&REV_03\3&E89B380&0&FB
   Driver: n/a
     Name: Intel(R) ICH9M/M-E Family 4 Port SATA AHCI Controller - 2929
Device ID: PCI\VEN_8086&DEV_2929&SUBSYS_306D103C&REV_03\3&E89B380&0&FA
   Driver: C:\Windows\system32\DRIVERS\msahci.sys, 6.00.6002.18005 (English), 4/11/2009 00:32:28, 27112 bytes
   Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.00.6002.18005 (English), 4/11/2009 00:32:52, 43496 bytes
   Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.00.6002.18005 (English), 4/11/2009 00:32:26, 19944 bytes
   Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.00.6002.18005 (English), 4/11/2009 00:32:42, 109032 bytes
     Name: Intel(R) ICH9M LPC Interface Controller - 2919
Device ID: PCI\VEN_8086&DEV_2919&SUBSYS_306D103C&REV_03\3&E89B380&0&F8
   Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.00.6001.18000 (English), 1/20/2008 20:23:01, 16440 bytes
     Name: Intel(R) 82801 PCI Bridge - 2448
Device ID: PCI\VEN_8086&DEV_2448&SUBSYS_306D103C&REV_93\3&E89B380&0&F0
     Name: Realtek RTL8102E/8103E Family PCI-E Fast Ethernet NIC (NDIS 6.0)
Device ID: PCI\VEN_10EC&DEV_8136&SUBSYS_306E103C&REV_02\4&2ABD10AA&0&00E3
   Driver: C:\Windows\system32\DRIVERS\Rtlh86.sys, 6.213.1110.2008 (English), 11/10/2008 14:26:00, 135680 bytes
   Driver: C:\Windows\system32\RtNicProp32.dll, 1.01.0716.2008 (English), 7/21/2008 07:08:40, 9728 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
SM AAC Decoder DMO,0x00200000,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
MP3 Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00600800,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
SM H264 Decoder DMO,0x00200000,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
MainConcept (Muvee) MPEG Demultiplexer,0x00400001,1,2,muveempgdmx.ax,7.03.0000.36147
CyberLink Audio Decoder (HP),0x00200000,1,1,CLAud.ax,6.03.0000.1029
CyberLink Audio Decoder (QP),0x00200900,1,1,CLAud.ax,6.03.0000.1029
PCM Video/SP Decoder,0x00200000,2,3,PCMRVSD.ax,6.00.0000.3922
MSDVD Audio Wizard (HP),0x00200910,1,1,CLAudWizard.ax,1.00.0000.1730
Full Screen Renderer,0x00200000,1,0,,6.06.6002.18725
CyberLink Volume Meter,0x00200000,1,0,HPVolumeMeter.ax,1.00.0000.0001
CyberLink MPEG Video Encoder,0x00200000,1,1,P2GVidEnc.ax,6.00.0001.2226
CyberLink TL MPEG Splitter,0x00200000,1,2,CLTLMSplter.ax,3.03.0000.1401
CyberLink DVD Navigator (HP),0x00200000,0,3,CLNavX.ax,7.00.0000.4710
Multiple File Output,0x00200000,2,2,WMM2FILT.dll,
WMT Black Frame Generator,0x00200000,1,1,WMM2FILT.dll,
WMT Import Filter,0x00200000,0,1,WMM2FILT.dll,
Cyberlink Track Filter,0x00200000,1,1,YCTrack.ax,1.01.0000.0222
PCM Audio Decoder,0x00200000,1,1,PCMRAud.ax,6.00.0000.4104
CyberLink MP3/WAV Wrapper,0x00200000,1,1,P2GMP3Wrap.ax,3.07.0000.1314
CyberLink Line21 Decoder Filter (HP),0x00200000,0,2,CLLine21.ax,4.00.0000.9027
PCM Video Regulator,0x00200000,1,1,PCMRResample.ax,4.00.0000.0126
DV Muxer,0x00400000,0,0,,6.06.6001.18000
CyberLink MPEGV Analyzer,0x00200000,1,1,PCMRmpegvanalyzer.ax,2.00.0000.2620
PCM MPEG Video Encoder,0x00200000,1,1,PCMRMpgVEnc2.ax,5.00.0000.1206
CyberLink File Map Source,0x00200000,0,1,PCMRFMSrc.ax,1.00.0000.0810
CyberLink AudioCD Filter,0x00200000,0,1,P2GAudioCD.ax,5.00.0000.1321
Color Space Converter,0x00400001,1,1,,6.06.6002.18725
CyberLink XDS Codec,0x00200000,1,0,PCMRxdscodec.ax,1.00.0000.0322
CyberLink Demultiplexer,0x00200000,1,0,PCMRdemuxer.ax,1.00.0000.7104
WMT Interlacer,0x00200000,1,1,WMM2FILT.dll,
WM ASF Reader,0x00400000,0,0,,11.00.6001.7000
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.6001.7000
AVI Splitter,0x00600000,1,1,,6.06.6002.18725
MainConcept (Muvee) MP4 Multiplexer,0x00200000,1,1,muveemp4mux.ax,7.07.0000.36147
VGA 16 Color Ditherer,0x00400000,1,1,,6.06.6002.18725
CyberLink Video Effect (HP),0x00200000,1,1,CLVidFx.ax,1.00.0000.1523
ReTimeStamp Filter,0x00200000,1,1,ReTimeStamp.ax,1.00.0000.0001
CyberLink Editing Service 3.0 (Source),0x00200000,0,2,P2GEdtKrn.dll,3.00.0000.2911
CyberLink TimeStretch Filter (HP),0x00200000,1,1,clauts.ax,1.00.0000.5423
Microsoft MPEG-2 Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,11.00.6001.7110
QuickPlay Video Regulator,0x00200000,1,1,PCMRResample.ax,4.00.0000.0126
CyberLink Audio Noise Reduction,0x00200000,1,1,PCMRAuNRWrapper.ax,1.00.0000.1318
CL_EVRWindow,0x00200000,0,0,PCMREvr.dll,1.00.0000.2315
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.6002.18363
Cyberlink SubTitle Importor (HP),0x00200000,1,1,CLSubTitle.ax,1.00.0000.1604
WMT Format Conversion,0x00200000,1,1,WMM2FILT.dll,
9x8Resize,0x00200000,1,1,WMM2FILT.dll,
MainConcept MPEG Splitter,0x001fffff,1,2,mcspmpeg.ax,1.01.4178.0000
MainConcept MPEG Audio Decoder,0x00600000,1,1,mcdsmpeg.ax,1.01.4178.0000
MainConcept MPEG Video Decoder,0x00600000,1,1,mcdsmpeg.ax,1.01.4178.0000
MainConcept MPEG Encoder,0x001fffff,2,1,mcesmpeg.ax,1.02.4178.0000
MainConcept MPEG Video Encoder,0x001fffff,1,1,mcevmpeg.ax,1.02.4178.0000
MainConcept MPEG Audio Encoder,0x001fffff,1,1,mceampeg.ax,1.02.4178.0000
MainConcept MPEG Multiplexer,0x001fffff,1,1,mcmuxmpeg.ax,1.30.4178.0000
CyberLink DVB Subtitle Decoder,0x00200000,1,1,PCMRDvbSub.ax,1.00.0000.4413
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.6002.18363
WMT Virtual Source,0x00200000,0,1,WMM2FILT.dll,
Microsoft TV Caption Decoder,0x00200001,1,0,MSTVCapn.dll,6.00.6002.18536
MJPEG Decompressor,0x00600000,1,1,,6.06.6002.18725
CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.00.6002.18242
MPEG-I Stream Splitter,0x00600000,1,2,,6.06.6002.18725
CyberLink Pipe Switch,0x00200000,1,1,PCMRPipSwch.ax,1.00.0000.3215
SAMI (CC) Parser,0x00400000,1,1,,6.06.6002.18725
P2G Video Decoder,0x00200000,2,3,P2GVSD.ax,6.00.0000.2310
MainConcept (Muvee) Stream Parser,0x00400001,1,2,muveempgdmx.ax,7.03.0000.36147
CyberLink XDS Codec,0x00200000,1,0,PCMRxdscodec.ax,1.00.0000.1016
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.6001.18000
CyberLink AVI Audio Time Regulator,0x00200000,1,1,PCMRAVI_AudTR.ax,1.00.0001.0213
CyberLink Demultiplexer,0x00200000,1,0,PCMRdemuxer.ax,1.00.0000.6327
CyberLink File Map Sink,0x00200000,1,0,PCMRFMSnk.ax,1.00.0000.0810
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.6002.18363
WMT AudioAnalyzer,0x00200000,1,1,WMM2FILT.dll,
CyberLink Audio Effect,0x00200000,1,1,PCMRAudFx.ax,6.00.0000.0805
MainConcept (Muvee Consumer) AVC/H.264 Video Decoder,0x00400001,1,2,muveestdavcvd.ax,7.05.0000.36147
YC_EVRWindow,0x00200000,0,0,YCEvr.dll,1.00.0000.2531
MediaWriter Filter,0x00200000,1,0,mediawriter.ax,6.00.0058.7993
Microsoft MPEG-2 Video Encoder,0x00200000,2,0,msmpeg2enc.dll,11.00.6001.7000
CL_EVRWindow,0x00200000,0,0,CLEvr.dll,1.00.0000.1717
CyberLink Push-Mode CLStream (cURL),0x00200000,0,1,CLStream(MultiLib).ax,1.01.0000.4421
Stretch Video,0x00200000,1,1,WMM2FILT.dll,
Internal Script Command Renderer,0x00800001,1,0,,6.06.6002.18725
CyberLink Video/SP Decoder,0x00600000,2,3,CLVSD.ax,8.02.0000.0630
CyberLink Video Regulator,0x00200000,1,1,P2GRGL.ax,2.00.0000.3328
QuickPlay MPEG Video Encoder,0x00200000,1,1,PCMRMpgVEnc.ax,5.00.0000.5229
P2G Audio Decoder,0x00200000,1,1,P2GAud.ax,6.01.0000.3601
MPEG Audio Decoder,0x03680001,1,1,,6.06.6002.18725
CyberLink Audio Decoder (HP),0x00200000,1,1,CLAud.ax,6.01.0008.5319
CyberLink Teletext Decoder Filter,0x00200000,0,2,PCMRttxdec.ax,2.05.0000.5730
DV Splitter,0x00600000,1,2,,6.06.6001.18000
CyberLink PTS Regulator,0x00200000,1,1,PCMPTSReg.ax,1.00.0000.1209
Video Mixing Renderer 9,0x00200000,1,0,,6.06.6002.18725
CyberLink Video Effect,0x00200000,1,1,P2GVidFx.ax,1.00.0000.2030
Cyberlink TS Information,0x00200000,1,0,PCMRTSInfo.ax,1.00.0000.3504
MainConcept (Muvee) AAC Decoder,0x00400001,1,1,muveedaac.ax,7.06.0000.36147
Cyberlink SubTitle(HP),0x00200000,1,1,CLSubTitle.ax,1.00.0000.4716
PCM SnapShotTIP Filter,0x00200000,1,1,PCMRSShot.ax,1.00.0000.2504
muvee Music Analyser,0x00200000,1,0,mvmanalyse.ax,6.00.0056.7596
muvee Source Filter,0x00200000,0,1,muveesource.ax,6.00.0058.7993
CyberLink Video Effect (HP),0x00200000,1,1,CLVidFx.ax,1.00.0000.2024
PCM Video Effect,0x00200000,1,1,PCMRVidFx.ax,1.00.0000.3512
CyberLink Audio Noise Reduction,0x00200000,1,1,P2GAuNRWrapper.ax,2.00.0000.1017
CyberLink EPG Decoder,0x00200000,1,1,PCMREpgDec.ax,1.00.0000.2917
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,11.00.6001.7000
HP VTK MPEG-1 Encoder,0x00200000,3,3,hpqvtk01.dll,120.00.0110.0011
Frame Eater,0x00200000,1,1,WMM2FILT.dll,
CyberLink Load Image Filter,0x00200000,0,1,CLImage.ax,3.00.0000.2307
CyberLink MPEG-2 Splitter,0x00200000,1,2,P2Gm2spliter.ax,2.04.0000.2301
CyberLink Video/SP Decoder (HP),0x00600000,2,3,CLVSD.ax,8.02.0000.0630
QuickPlay Demultiplexer,0x00200000,1,0,CLDemuxer.ax,1.00.0000.5609
Allocator Fix,0x00200000,1,1,WMM2FILT.dll,
CyberLink Audio VolumeBooster,0x00200000,1,1,P2GVB.ax,1.00.0000.1008
ACM Wrapper,0x00600000,1,1,,6.06.6002.18725
Cyberlink Streamming Filter,0x00200000,0,1,CLStream.ax,1.01.0000.4624
CyberLink Teletext Decoder Filter,0x00200000,0,2,PCMRttxdec.ax,2.05.0000.4428
Video Renderer,0x00800001,1,0,,6.06.6002.18725
QuickPlay SnapShotTIP Filter,0x00200000,1,1,PCMRSShot.ax,1.00.0000.2504
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.6002.18363
Capture ASF Writer,0x00200000,0,0,WMM2FILT.dll,
Cyberlink Dump Dispatch Filter,0x00200000,1,0,P2GDumpDispatch.ax,1.02.0001.2412
CyberLink AudioCD Filter (HP),0x00600000,0,1,CLAudioCD.AX,5.00.0000.0912
CyberLink MPEG-4 Splitter,0x00200000,1,2,clm4splt.ax,1.00.0000.4924
Line 21 Decoder,0x00600000,1,1,,6.06.6002.18533
CyberLink Push-Mode CLStream,0x00200000,0,1,CLStream(PushMode).ax,1.01.0000.4705
Video Port Manager,0x00600000,2,1,,6.06.6002.18725
Video Renderer,0x00400000,1,0,,6.06.6002.18725
WAV Dest,0x00200000,0,0,wavdest.ax,
QuickTime Encoder,0x00200000,1,0,quicktimesink.ax,6.00.0058.7993
CyberLink Audio Effect (HP),0x00200000,1,1,claudfx.ax,6.00.0000.5103
Bitmap Generate,0x00200000,1,1,WMM2FILT.dll,
CyberLink Line21 Decoder Filter,0x00200000,0,2,PCMRLine21.ax,4.01.0000.0820
CyberLink Audio Resampler,0x00200000,1,1,P2GAuRsmpl.ax,1.00.0000.2625
Proxy Sink,0x00200000,1,0,WMM2FILT.dll,
Proxy Source,0x00200000,0,1,WMM2FILT.dll,
CyberLink MPEG Splitter(Scramble),0x00200000,1,2,CLSplter.ax,3.02.0000.4119
HP VTK Rotate Filter,0x00200000,1,1,hpqvtk01.dll,120.00.0110.0011
WM ASF Writer,0x00400000,0,0,,11.00.6001.7000
QuickPlay Audio Resampler,0x00200000,1,1,PCMRAuRsmpl.ax,1.00.0000.2304
CyberLink MPEG-1 Splitter,0x00200000,1,2,P2Gm1spliter.ax,2.04.0000.2301
CyberLink Tzan Filter,0x00200000,1,1,CLTzan.ax,3.00.0000.2215
MES Video Source,0x00200000,0,1,mesvideosource.ax,6.00.0058.7993
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.00.6001.18000
PCM MPEG-2 Splitter,0x00200000,1,2,PCMRM2Splter.ax,2.02.0000.4328
CyberLink TimeStretch Filter,0x00200000,1,1,PCMRAuts.ax,1.00.0000.2108
WMT Sample Information Filter,0x00200000,1,1,WMM2FILT.dll,
File writer,0x00200000,1,0,,6.06.6001.18000
Cyberlink File Reader (Async.),0x00200000,0,1,P2GReader.ax,3.00.0000.3016
CyberLink SBE Source Filter,0x00200000,0,0,PCMRsbesrc.ax,2.00.0000.2620
CyberLink M2V Writer,0x00200000,1,0,P2GM2VWriter.ax,1.03.0000.2017
QuickPlay MPEG Video Encoder 2,0x00200000,1,1,PCMRMpgVEnc2.ax,5.00.0000.1206
PCM Audio Encoder,0x00200000,2,0,PCMRaudenc.ax,2.01.0000.2031
Cyberlink Dump Filter,0x00200000,1,0,P2GDump.ax,3.00.0000.7122
PCM Dump Filter,0x00200000,1,0,PCMRdump.ax,3.00.0000.8231
CyberLink Line21 Decoder Filter (QP),0x00200000,0,2,CLLine21.ax,4.00.0000.7602
CyberLink Video Stabilizer,0x00200000,1,1,P2GVideoStabilizer.ax,1.00.0000.1017
CyberLink TL MPEG Splitter,0x00200000,1,2,YCTLMSplter.ax,3.02.0000.2219
Cyberlink TS Filter Filter,0x00200000,1,1,PCMRTSFF.ax,1.00.0000.3504
Cyberlink TS Information,0x00200000,1,0,PCMRTSInfo.ax,1.00.0000.2718
CyberLink MPEG Splitter,0x00200000,1,2,CLSplter.ax,3.02.0000.3829
CyberLink SBE Filter,0x00200000,0,0,PCMRsbe.ax,2.00.0000.3207
CyberLink DVD Navigator (HP),0x00200000,0,3,CLNavX.ax,7.00.0000.4704
muvee Video Analyser,0x00200000,1,0,mvvanalyse.ax,6.00.0056.7596
CyberLink PCM Wrapper,0x00200000,1,1,P2GPCMEnc.ax,1.01.0000.0321
DVD Navigator,0x00200000,0,3,,6.06.6002.18533
WMT DV Extract,0x00200000,1,1,WMM2FILT.dll,
Overlay Mixer2,0x00200000,1,1,,6.06.6002.18533
CyberLink MPEGV Analyzer,0x00200000,1,1,PCMRmpegvanalyzer.ax,2.00.0000.3207
mvAudioScope,0x00200000,1,0,mvaudioscope.ax,6.00.0058.7993
Bouncing Ball,0x00200000,0,1,,
PCM Audio Resampler,0x00200000,1,1,PCMRAuRsmpl.ax,1.00.0000.2304
MainConcept (Muvee2) Layer II Audio Decoder,0x00400001,1,1,muvee2l2ad.ax,7.04.0000.34713
CyberLink DVB Subtitle Decoder,0x00200000,1,1,PCMRDvbSub.ax,1.00.0000.3927
CyberLink MP3 Wrapper-PCM,0x00200000,1,1,PCMRmp3wrap.ax,1.00.0000.0000
MainConcept (Muvee) MPEG Multiplexer-Plus,0x00200000,1,1,muveempeg2mux.ax,7.06.0000.36147
AVI Draw,0x00600064,9,1,,6.06.6002.18725
MainConcept (Muvee) MPEG Multiplexer,0x00200000,1,1,muveemuxmpeg.ax,7.03.0000.36147
muvee Deinterlace Filter,0x00200000,1,1,mvdeinterlace.ax,6.00.0058.7993
Microsoft MPEG-2 Audio Encoder,0x00200000,2,0,msmpeg2enc.dll,11.00.6001.7000
CyberLink Demultiplexer(Scramble),0x00200000,1,0,CLDemuxer.ax,1.00.0000.6807
WST Pager,0x00800000,1,1,WSTPager.ax,6.06.6001.18000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.6002.18363
Record Queue,0x00200000,1,1,WMM2FILT.dll,
QuickPlay Video/SP Decoder,0x00200000,2,3,PCMRVSD80.ax,8.02.0000.1106
DV Video Decoder,0x00800000,1,1,,6.06.6001.18000
PCM MPEG Muxer,0x00200000,2,1,PCMRMpgMux.ax,5.01.0000.1217
CyberLink Audio Decoder,0x00200000,1,1,CLAud61.ax,6.01.0008.5503
CyberLink SnapShotTIP Filter,0x00200000,1,1,CLSShot.ax,1.00.0000.2802
MainConcept (Muvee) MPEG-2 Video Decoder,0x00400001,2,2,muveem2vd.ax,7.05.0000.36147
CyberLink WMV/WMA Demultiplexer,0x00200000,1,2,CLWMFDemux.ax,1.00.0000.4323
CyberLink Video Regulator,0x00200000,1,1,CLRGL.ax,3.00.0000.1513
CyberLink SBE Source Filter,0x00200000,0,0,PCMRsbesrc.ax,2.00.0000.3207
HP VTK Frame Grabber Filter,0x00200000,1,1,hpqvtk01.dll,120.00.0110.0011
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.6002.19118
Null Renderer,0x00200000,1,0,qedit.dll,6.06.6002.19118
CyberLink WebCamera NULL Render,0x00200000,0,0,YCWEBCAMERARENDER.ax,2.00.3519.2318
WMT Log Filter,0x00200000,1,1,WMM2FILT.dll,
QuickPlay MPEG-2 Splitter,0x00200000,1,2,PCMRM2Splter.ax,2.02.0000.2114
QuickPlay Audio Decoder,0x00200000,1,1,PCMRAudX.ax,6.03.0000.1029
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.6002.18496
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,11.00.6001.7000
CyberLink Video Regulator,0x00200000,1,1,YCRgl.ax,3.00.0000.1228
WMT Virtual Renderer,0x00200000,1,0,WMM2FILT.dll,
IDM Filter,0x00200000,1,1,idmf.ax,1.00.0000.3909
CyberLink TimeStretch Filter(HomeNetwork),0x00200000,1,1,clauts.ax,1.00.0000.5423
Cyberlink TS Filter Filter,0x00200000,1,1,PCMRTSFF.ax,1.00.0000.2718
CyberLink Video/SP Decoder (QP),0x00200000,2,3,CLVSD.ax,8.02.0000.0619
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.6002.18363
muvee FileDump Filter,0x00200000,1,0,mvfiledump.ax,6.00.0058.7993
PCM RTP Source Filter,0x00200000,0,1,PCMRRTPSrc.ax,1.00.0000.1826
CyberLink Audio Commercial Cut Analyzer,0x00200000,1,1,CLAudCM.ax,1.00.0000.2026
CyberLink TimeStretch Filter (CES),0x00200000,1,1,P2Gauts.ax,1.00.0000.2212
Smart Tee,0x00200000,1,2,,6.06.6001.18000
Overlay Mixer,0x00200000,0,0,,6.06.6002.18533
CyberLink TL MPEG Splitter,0x00200000,1,2,P2GTLMSplter.ax,3.02.0000.2219
AVI Decompressor,0x00600000,1,1,,6.06.6002.18725
CyberLink MPEG Muxer,0x00200000,2,1,P2GMpgMux.ax,5.01.0000.1723
WMT MuxDeMux Filter,0x00200000,0,0,WMM2FILT.dll,
CyberLink Video/SP Decoder (HP),0x00200000,2,3,CLVSD.ax,8.02.0000.1117
CyberLink Video Effect,0x00200000,1,1,CLVidFx.ax,1.00.0000.2024
NetBridge,0x00200000,2,0,netbridge.dll,6.01.6001.18000
CyberLink Demultiplexer (HP),0x00200000,1,0,CLDemuxer.ax,1.00.0000.5405
CyberLink Audio Noise Reduction,0x00200000,1,1,CLAuNRWrapper.ax,2.00.0000.1611
CyberLink Audio Effect (HP),0x00200000,1,1,claudfx.ax,6.00.0000.1223
AVI/WAV File Source,0x00400000,0,2,,6.06.6002.18725
WMT Volume,0x00200000,1,1,WMM2FILT.dll,
Wave Parser,0x00400000,1,1,,6.06.6002.18725
MIDI Parser,0x00400000,1,1,,6.06.6002.18725
Multi-file Parser,0x00400000,1,1,,6.06.6002.18725
File stream renderer,0x00400000,1,1,,6.06.6002.18725
CyberLink SBE Filter,0x00200000,0,0,PCMRsbe.ax,2.00.0000.2620
MES Audio Source,0x00200000,0,1,mesaudiosource.ax,6.00.0058.7993
CyberLink WMV Dumper (YouCam),0x00200000,2,0,YCWMVDump.ax,1.00.0000.2303
HP VTK Resize Filter,0x00200000,1,1,hpqvtk01.dll,120.00.0110.0011
CyberLink Audio Spectrum Analyzer (HP),0x00200000,1,1,CLAudSpa.ax,1.00.0000.0924
CyberLink Audio Resampler,0x00200000,1,1,CLAuRsmpl.ax,2.00.0000.0411
WMT VIH2 Fix,0x00200000,1,1,WMM2FILT.dll,
QuickTime Source Filter,0x00200000,0,1,quicktimesource.dll,6.00.0058.7993
Microsoft MPEG-1/DD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,11.00.6001.7000
AVI Mux,0x00200000,1,0,,6.06.6001.18000
CyberLink DVD Navigator (QP3),0x00200000,0,3,CLNavX.ax,7.00.0000.4710
CyberLink Audio Spectrum Analyzer (HomeNetwork),0x00200000,1,1,CLAudSpa.ax,1.00.0000.0924
muvee WAV Encoder,0x00200000,0,0,mvwavencoder.ax,9.00.0000.0000
CyberLink Scene Detect Filter 2,0x00200000,1,1,CLScnDt2.dll,1.01.0000.3202
Line 21 Decoder 2,0x00600002,1,1,,6.06.6002.18725
File Source (Async.),0x00400000,0,1,,6.06.6002.18725
File Source (URL),0x00400000,0,1,,6.06.6002.18725
CyberLink Line21 Decoder Filter (HP),0x00200000,0,2,CLLine21.ax,4.00.0001.7527
Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.6002.18005
P2G Video Regulator,0x00200000,1,1,P2GResample.ax,2.05.0000.1818
QuickPlay MPEG Muxer,0x00200000,2,1,PCMRMpgMux.ax,5.01.0000.1129
AudioRecorder WAV Dest,0x00200000,0,0,,6.00.6001.18000
AudioRecorder Wave Form,0x00200000,0,0,,6.00.6001.18000
SoundRecorder Null Renderer,0x00200000,0,0,,6.00.6001.18000
P2G Audio Encoder,0x00200000,2,0,P2GAudEnc.ax,2.00.0000.4815
CyberLink UltraSpeed/SVRT Demultiplexer,0x00200000,1,0,CLEdtDemuxer.ax,1.02.0001.6529
Cyberlink File Reader (Async.),0x00400000,0,1,CLAsyReader.ax,1.00.0000.1319
CyberLink Audio Decoder,0x00200000,1,1,CLAud.ax,6.01.0008.4721
QuickPlay Video Effect,0x00200000,1,1,PCMRVidFx.ax,1.00.0000.3512
QuickPlay Audio Encoder,0x00200000,2,0,PCMRaudenc.ax,2.01.0000.2031
KsProperty Interface Null,0x00200000,1,1,PCMRKsPropertyNull.ax,9.00.0000.0000
QuickPlay Dump Filter,0x00200000,1,0,PCMRdump.ax,3.00.0000.8618
Infinite Pin Tee Filter,0x00200000,1,1,,6.06.6001.18000
WMT Switch Filter,0x00200000,1,1,WMM2FILT.dll,
CyberLink DTVCC Decoder Filter,0x00200000,0,2,PCMRDTVCC.ax,1.00.0000.2112
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.00.6002.18005
CyberLink MPEG Video Encoder,0x00200000,1,1,PCMRMpgVEnc.ax,5.00.0000.4811
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,WMM2FILT.dll,
MainConcept (Muvee) MP4 Demultiplexer,0x00400001,1,2,muveemp4demux.ax,7.07.0000.36147
CyberLink MPEG Splitter,0x00200000,1,2,CLSplter.ax,3.01.0000.3423
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.6002.18496
CyberLink WMV Dumper(HP),0x00200000,2,0,PCMWMVDump.ax,1.00.0000.1526
CyberLink SAC Video Decoder,0x00200000,2,3,CLVSD.ax,8.03.0000.1017
MPEG Video Decoder,0x40000001,1,1,,6.06.6002.18725
CyberLink MPEG Decoder,0x00200000,2,3,P2GMVD.ax,5.00.0000.0929
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,,6.00.6001.18000
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,,6.06.6001.18000
MJPEG Compressor,0x00200000,0,0,,6.06.6002.18725
Cinepak Codec by Radius,0x00200000,1,1,,6.06.6001.18000
Intel IYUV codec,0x00200000,1,1,,6.06.6001.18000
Microsoft RLE,0x00200000,1,1,,6.06.6001.18000
Microsoft Video 1,0x00200000,1,1,,6.06.6001.18000
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IMA ADPCM,0x00200000,1,1,,6.06.6002.18725
Microsoft ADPCM,0x00200000,1,1,,6.06.6002.18725
GSM 6.10,0x00200000,1,1,,6.06.6002.18725
CCITT A-Law,0x00200000,1,1,,6.06.6002.18725
CCITT u-Law,0x00200000,1,1,,6.06.6002.18725
MPEG Layer-3,0x00200000,1,1,,6.06.6002.18725
Audio Capture Sources:
Integrated Microphone Array (ID,0x00200000,0,0,,6.06.6001.18000
External Mic (IDT High Definiti,0x00200000,0,0,,6.06.6001.18000
Stereo Mix (IDT High Definition,0x00200000,0,0,,6.06.6001.18000
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,,6.06.6002.18725
Microsoft GS Wavetable Synth,0x00200000,1,0,,6.06.6002.18725
WDM Streaming Capture Devices:
,0x00000000,0,0,,
MicIn,0x00200000,1,1,,6.00.6001.18000
MuxedIn1,0x00200000,1,1,,6.00.6001.18000
,0x00000000,0,0,,
USB Video Device,0x00200000,1,2,,6.00.6001.18000
WDM Streaming Rendering Devices:
HpOut,0x00200000,1,1,,6.00.6001.18000
,0x00000000,0,0,,
,0x00000000,0,0,,
Speaker,0x00200000,1,1,,6.00.6001.18000
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6002.18496
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6002.18496
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6002.18496
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6002.18496
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.6002.18005
Video Capture Sources:
HP web camera filter,0x00200000,0,1,YCWebCameraSource.ax,2.00.3519.2318
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.6002.18496
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.6002.18496
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,EncDec.dll,6.06.6002.18528
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.6002.18528
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.6002.18528
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers and Headphones (IDT Hi,0x00200000,1,0,,6.06.6002.18725
CyberLink Audio Renderer,0x00200000,1,0,CLADR.ax,6.00.0000.2108
CyberLink Audio Renderer (HP),0x00200000,1,0,CLADR.ax,6.00.0000.5222
Default DirectSound Device,0x00800000,1,0,,6.06.6002.18725
Default WaveOut Device,0x00200000,1,0,,6.06.6002.18725
DirectSound: Independent Headphones (IDT High Definition Audio CODEC),0x00200000,1,0,,6.06.6002.18725
DirectSound: Speakers and Headphones (IDT High Definition Audio CODEC),0x00200000,1,0,,6.06.6002.18725
Independent Headphones (IDT Hig,0x00200000,1,0,,6.06.6002.18725
I'm now getting a crash on the "Non-HTML5 video", and the flash logo no longer shows on the page:
Adobe Employee ,
It looks like you're about four years behind on drivers for your graphics hardware.
Here's a link to the current installer for 32-bit Vista:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=22163&lang=eng&ProdId=2991
I'm not sure that this will fix the issue since you're seeing it both with hardware acceleration enabled and disabled, though.
In Firefox, if you type about:crashes in the address bar, you'll get a list of crashes.
Click the link and it will submit the report to Mozilla and open a new page.  Copy and paste the address from the new window into a reply.  If you have more than one from the last couple days, a few would be helpful.
In Firefox, if you choose Menu (hamburger icon) > Help (?) > Restart with Add-Ons Disabled, does this crash persist?
Thanks very much for your help  .... you've given me a number of things to check, and I'll continue to work on this over the next week or so.  In the meantime, if I need to play any videos, I just use Google Chrome.
Thanks Again  ... you've been very helpful!
