4 Replies Latest reply: Nov 11, 2014 3:51 PM by nokonoko56 RSS
    Gestures not working
    TimT Community Member
      I'm using the following script to enable the swipe gestures on iOS...
      Movie Script
      on startMovie
        _touches.registerGesture([#swipeRightGesture:#handleSwipeRight])
        _touches.registerGesture([#swipeLeftGesture:#handleSwipeLeft])
      end
      Frame Script
      on handleSwipeRight
        go next
      end
      However this dosen't work - ie nothing happens when I swipe the screen (on either the iphone iOS7 or ipad iOS6. Is this how the code should be implemented?
        • 1. Re: Gestures not working
          SeanWilson Community Member
          Is it possible the frameScript isn't "active" when the gesture is made? That is, that the playhead isn't on the frame in question. Try placing your #handleSwipeRight and #handleSwipeLeft handlers in a movie script
          • 2. Re: Gestures not working
            The playhead is on the frame correct frame when the gesture is made. It's the first frame of the movie.
            I added the hanndles to the movie script...
            on startMovie
            end
            on handleSwipeRight
            go previous
            end
            on handleSwipeRight
            go next
            end
            And in the frame script...
            on exitFrame me
              go to the frame
              handleSwipeRight
              handleSwipeLeft
            end
            This sort of worked - but the it flashed back and forwards between frames without the screen being touched.
            I changed the frame script to the folowing and it worked...
            on exitFrame me
              go to the frame
            end
            on handleSwipeRight
              go previous
            end
            on handleSwipeLeft
              go next
            end
            • 3. Re: Gestures not working
              I've got the left and right gestures working okay, but becuase the handler is in the movie script and not the frame script I'm having problems changing the destination of the gesture. It's okay if the swipes are alway going to the previous or next marker. But it gets more complex if I want to start having the playhead going to different frames.
              I ended up creating a global varaible to determine which frame is the next destination. The variable is set in the frame script.
              Movie Script
              on startMovie
                global gwhatframeLeft
                global gwhatframeRight
                set gwhatframeLeft = "2"
                set gwhatframeRight = "60" --last frame
              end
              on handleSwipeLeft
                go to frame gwhatframeLeft
              end
              on handleSwipeRight
                go to frame gwhatframeRight
              end
              Frame Script (Frame "2")
              on exitFrame me
                go to the frame
                global gwhatFrameLeft
                set gwhatFrameLeft = "3"
                global gwhatFrameRight
                set gwhatFrameRight = "1" --first frame
              end
              This seems like an awkward way to do this (It will make testing a lot more time consuming) - is there a more stright forward way.
              • 4. Re: Gestures not working
                nokonoko56
                First, Director (12) is started and the following script is described.
                Movie script
                on startMovie
                   _touches.registerGesture ([#swipeRightGesture:#handleSwipeRight])
                   --It recognizes also by "on prepareMovi" or "on startMovie".
                end
                on handleSwipeRight
                   member("momo").text = the long time & "start"
                   --code to handle Right Swipe
                end
                "on startMovie" is recommended although recognized also by "on prepareMovie" or "on startMovie". Those with a possibility of stopping moving by "on prepareMovie" when another Handler is put in.
                And use a movie script by a property inspector. This is important. Unless it comes out, the Handler written in here does not move.
                If it moves by Director in order to move by ios, an error will come out.It is published and used for ios.
                detailed my Homepage(Candy's Homepage)
