Show 1 reply
1. Re: Exporting an Access form to print as a PDF, some dates export fine some show up as #####
Bill@VT Nov 11, 2014 5:30 PM (in response to thecrowe74)Adjust the size of the fields in Acrobat. You might go to print, select the Adobe PDF printer, and check the preview -- my guess is you will see the #### there too. If so, it is a MS issue with adjusting to the printer (reflow). In that case, changing the size of the fields or the font size is the proper solution in Access.
