1. Re: PSE 12 keeps FREEZING when using Brushes
PSE12 & OSX10.10 Oct 18, 2014 4:23 AM (in response to cb.cowan)I have exactly the same issue.
2. Re: PSE 12 keeps FREEZING when using Brushes
Cliff Jenkins Oct 18, 2014 5:28 AM (in response to cb.cowan)Same PSE 12/Yosemite freezing problem! Will paying for PSE 13 solve the Freezing Problem???
3. Re: PSE 12 keeps FREEZING when using Brushes
cb.cowan Oct 18, 2014 7:08 AM (in response to Cliff Jenkins)I downloaded PSE 13 trial and it worked perfectly. I don't think that we should have to pay for an upgrade when the lower version should work fine. I feel that either Adobe fix the issue or upgrade us for free! I will ask the question once I find who I should contact.
4. Re: PSE 12 keeps FREEZING when using Brushes
Y Ffwrnice Oct 18, 2014 7:23 AM (in response to cb.cowan)I have the same problem with PSE 12 after upgrading Macbook Pro to OS Yosomite. Tried looking for support from Adobe but unable to find email support address. Does anyone have their address?
5. Re: PSE 12 keeps FREEZING when using Brushes
pse 12 Oct 18, 2014 7:31 AM (in response to cb.cowan)Ditto! It seems to be any of the enhance and draw tools.
6. Re: PSE 12 keeps FREEZING when using Brushes
Cliff Jenkins Oct 18, 2014 2:31 PM (in response to cb.cowan)Thank you so much for the share . . . I owe you one!!
Cliiff
Jenkins Cliff
1203 Ala Alii St. Apt 86
Honolulu, HI. 96818
(808) 676-7103
7. Re: PSE 12 keeps FREEZING when using Brushes
abbrock22 Oct 18, 2014 7:07 PM (in response to cb.cowan)I also just upgraded my MacBook Pro to the Yosemite and I cannot use any tools in Elements. It gets stuck on them and then won't do anything. Tried resetting the tools like suggested but no help! I'm assuming it's because of the upgrade but this needs to be fixed ASAP!!! If anyone has any answers please let me know also! Thanks so much!!!
8. Re: PSE 12 keeps FREEZING when using Brushes
cb.cowan Oct 19, 2014 7:16 AM (in response to cb.cowan)Looking at other post some people said that Adobe has pretty much said too bad you need to buy PSE13, with that attitude I will find a different program!!
9. Re: PSE 12 keeps FREEZING when using Brushes
Mariannesfoto Oct 19, 2014 9:44 AM (in response to cb.cowan)I have the same problem.
I tried this tips that I got, but it didn't help.
Delete:
com.adobe.PhotoshopElements.plist
Adobe Photoshop Elements < version > Paths
Adobe Photoshop Elements < version > Settings
com.adobe.Elements Organizer. < version >.plist
com.adobe.ElementsOrganizer< version>.plist
and any lockfiles with the same names, then go to Saved Application States (at the same level as preferences) and delete any for PSE, then repair permissions and try again.
I hope someone will post back with a solution!
10. Re: PSE 12 keeps FREEZING when using Brushes
Diers Oct 19, 2014 11:09 AM (in response to Mariannesfoto)I have the same Problem.
11. Re: PSE 12 keeps FREEZING when using Brushes
Barbara B. Oct 19, 2014 11:50 AM (in response to cb.cowan)It's been suggested that this problem only happens when using trackpads. Are you all using trackpads? If so, do you have the same issues with a mouse?
12. Re: PSE 12 keeps FREEZING when using Brushes
Mariannesfoto Oct 19, 2014 11:59 AM (in response to Barbara B.)Yes, trackpad. I haven't the possibility to use a mouse.
13. Re: PSE 12 keeps FREEZING when using Brushes
Diers Oct 19, 2014 12:06 PM (in response to Mariannesfoto)Yes, with a mouse works. I hope Adobe fix with this with a update.
14. Re: PSE 12 keeps FREEZING when using Brushes
Y Ffwrnice Oct 19, 2014 1:40 PM (in response to Barbara B.)Cheers thanks for the tip. I have a macbook Pro retina and also had the problem of PSE 12 freezing after downloading O S Yosomite. But tried using. a mouse rather than the trackpad as you suggested and it works great. I would rather use the trackpad but at least now I can use the PSE 12 software Thanks!
15. Re: PSE 12 keeps FREEZING when using Brushes
StevethePoet Oct 19, 2014 4:32 PM (in response to cb.cowan)I've been going nuts, killing Photoshop Elements and restarting it, trying to get the brush to work. I truly appreciate this forum for letting me know I am not alone, and suggesting the mouse fix. I'll plug one in to my MacBook Pro and hope Adobe/Apple work together to get this fixed for us Elements 12 users. I am not yet ready to upgrade to 13 to remedy a bug that should have been fixed before the release of Yosemite.
Please, Adobe, you need to collaborate with Apple to fix this issue.
16. Re: PSE 12 keeps FREEZING when using Brushes
Joebrummer Nov 11, 2014 6:04 PM (in response to cb.cowan)I am having the same issue. I uninstalled PSE 12 and reinstalled it, but it did not solve the problem.
18. Re: PSE 12 keeps FREEZING when using Brushes
Cliff Jenkins Nov 11, 2014 7:48 PM (in response to Joebrummer)Stay with PSE on Mavericks! or Buy PSE 13!!
Cliff
Jenkins Cliff
Honolulu, HI. 96818
(808) 676-7103
19. Re: PSE 12 keeps FREEZING when using Brushes
StevethePoet Nov 12, 2014 4:54 AM (in response to cb.cowan)Adobe has a fix for this. You can download a plug-in that takes care of the problem. They are working with Apple to coordinate a permanent fix.
Another alternative is to use a mouse instead of the trackpad - the issue is with trackpad commands.
Hope this helps - you don't need to stick with Mavericks or buy PSE 13.
20. Re: PSE 12 keeps FREEZING when using Brushes
cb.cowan Nov 12, 2014 6:01 AM (in response to StevethePoet)Where is the plug in at, Adobe or apple?
