1. Re: Bookmarking
Mstpierre112 Nov 11, 2014 10:43 AM (in response to Mstpierre112)I should probably mention that I am running courses off of an internal server, not an LMS, so I'm thinking maybe this is controlled by the LMS. In that case, is there any alternative when distributing courses without an LMS? I am using the ALS dashboard to track usage.
2. Re: Bookmarking
Jorma Jennings Nov 11, 2014 1:01 PM (in response to Mstpierre112)In the reporting settings, where you select SCORM or AICC, you can set the escape and resume values to match what your server would be looking for. Since you are not running this off of an LMS, I'm not sure that your server will leverage these values for individuals accessing the content in multiple sittings. So, without an LMS, the point may be moot, but it can be worth exploring. I don't have much experience trying to get this to work off of a web server, but others here may have more insight to getting that to work.
3. Re: Bookmarking
alpi agarwal Nov 11, 2014 8:40 PM (in response to Mstpierre112)Hi,
The resume course scenario is indeed controlled by the LMS. Currently this is not possible with the internal server.
The course will always start from the beginning if hosted on a internal server.
Nice to hear that you are using ALS dashboard for analytics
Alpi Agarwal
Adobe Presenter Engineering Team
4. Re: Bookmarking
Mstpierre112 Nov 12, 2014 8:14 AM (in response to alpi agarwal)Thanks for the response, that helps with my confusion.
As a side note -- is there a good source for training/documentation on the ALS Dashboard? I'm sure there are features I am not taking advantage of.
Michelle
