1. Re: Why is the merge parent creating folders for and publishing all the contents of the child projects?
Willam van Weelden Nov 10, 2014 7:02 AM (in response to Tatu Mbili)Hi,
On creating merged help, the master project will create empty folders for all children in the folder mergedProjects. Having those three empty folders is what I'd expect. From your child project you generate to the Child 1 and Child 2 folder. For every child project you take to the output, RoboHelp creates a folder. Why it needs it? Probably there is some script checking that folder, but I'm not sure.
As to why you have two Child 1 and Child1 folder, in your main TOC, you probably still have a placeholder for the Child1.
Kind regards,
Willam
2. Re: Why is the merge parent creating folders for and publishing all the contents of the child projects?
Tatu Mbili Nov 10, 2014 11:54 AM (in response to Willam van Weelden)Thanks for the reply, Willam. I'm not sure I was very clear. What I was expecting is exactly what you describe, that two empty folders will be created, one for each child (I only have two). The problem is that that is not what is happening: when I generate and publish the parent to a completely clean location, i.e., delete all previous content from the publish location, the child folders are placed under mergedProjects but they are full! They contain the child projects, which are published at the same time, and from what I know, this is not supposed to happen, they are supposed to be blank, until I publish the two child projects there.
Once I know why this is happening, I'll come back and address the second part of my problem above.
Thanks.
Helen
3. Re: Why is the merge parent creating folders for and publishing all the contents of the child projects?
Willam van Weelden Nov 11, 2014 7:03 AM (in response to Tatu Mbili)Does this also happen if you remove the !SSL! folder? It seems that somehow an old output is retained even though it should be removed.
Kind regards,
Willam
4. Re: Why is the merge parent creating folders for and publishing all the contents of the child projects?
Tatu Mbili Nov 11, 2014 8:33 PM (in response to Willam van Weelden)Where am I supposed to remove the SSL folder from? My project is under version control through TFS: am I removing this from the file structure before publish? In the parent? In the child ones?
My local copy of the parent has an SSL folder which contains an empty WebHelp folder only. The corresponding folder on the TFS server contains no SSL folder.
My local copy of Child 1 has an SSL folder with a bunch of folders in it, some of them very old publishes, some very recent. The corresponding location on the TFS server has no SSL folder at all.
My local copy of Child 2 has two empty folders in SSL. The corresponding location on the TFS server has no SSL folder at all.
Is it these local copies I should be deleting using Win Explorer?
I'm trying to be really careful here as I really don't want to mess up what was a project that was working really well.
Helen
5. Re: Why is the merge parent creating folders for and publishing all the contents of the child projects?
Willam van Weelden Nov 12, 2014 2:55 AM (in response to Tatu Mbili)You can remove the SSL from your local copies. The main thing is that there should not be an SSL folder in TFS. You can always zip up the project folder before deleting as to never lose anything.
Also, what is the directory you are generating to? Can you clear that directory completely and try again?
Kind regards,
Willam
