I cannot figure out how to make sure Robohelp 11 uses Epub 3 as the default standard for generating epubs. In the Single Source Layouts dock Ebook (Primary Layout) has been set to Epub 3. But when opening a sample job and using Generate, the Epub standard is set to Epub 2.0.1. Why is that and can I change it and make sure it uses epub 3?
What do you mean by 'sample job'?
When you use the SSL, you should get ePub 3, if you use the ebook generation script, you will get 2.0.1.
Kind regards,
Willam
Aha! Thanks. I believe you answered my question. I can generate for epub 3 using the ssl, but I still wonder why the ebook generation script has been setup for 2.0.1. Bear with me please - I am new at Robohelp 🙂
regards
Bjørn
The ePub script is older, starting in RoboHelp 10 as a type of tryout. In RH11, Adobe introduced the SSL with ePub 3. And the script is still available. That's why there are two ways of creating an ebook.
Kind regards,
Willam
