HI,
I am running OS 10.9.5, I am trying to update Flash, have done an uninstall of flash, have tried to boot in safe mode, have tried to install offline. The best I can get is 97% then it hangs up. I have been dealing with this headache for 3 weeks and finally called Apple and they referred me to you. I need help, I need to access sites to get some work out asap. Thanks in advance.
Jackie
I wiped my computer and did a complete reinstall of everything, then installed flash, then migrated my personal data and files back over.
I was just getting to 30% and this worked for me. http://download.macromedia.com/pub/flashplayer/current/support/install_flash_player_osx.dm g
I tried it just now.... no luck. Gets me to 95%. First I made sure all other downloads were not running and did a reboot.... anything else to try?
First, please try this link: http://fpdownload.macromedia.com/pub/flashplayer/current/support/install_flash_player_osx.dmg
If that doesn't get it done, let's try doing an uninstall and reinstall:
Uninstall Flash Player | Mac OS
Then re-run the installer you downloaded above.
Let me know if you run into trouble.
The link is dead.. I am sorry, just now getting around to doing this and it is SO frustrating. I called Apple again this morning and we tried everything they could think of and even installed a new OS in safe mode. Why is this happening to me? What else can I try??
We released a new version on Tuesday and the link changed:
http://fpdownload.macromedia.com/pub/flashplayer/latest/help/install_flash_player_osx.dmg
Ok I tried it and it got hung up at 95%.... I even left it for an hour just to see if it would finish the install but still 95%. I have already done an uninstall, just FYI.. anything else?
Please try a clean install:
How to perform a "clean install" of Flash Player in Mac OS X
the offline installer link is dead.... is there a new one?
but I have done that in the past and made sure those files are trashed, rebooted, etc. Is there something I should do with shockwave? I am just guessing...
You can try repeating the process in Safe Mode.
I have done that. I even did a safe reinstall of the OS....
re: offline installer - see my comment from 11/13/2014 - 9:41 AM. I just verified that the link is working for me.
Have you done it since you did a safe reinstall of the OS?
I haven't. I will try again but the offline link isn't working for me, I checked again...... thanks for being patient
Ok just tried the offline link. Hangs up at 95%
Can you please give me the contents of /Users/<you>/Library/Logs/FlashPlayerInstallManager.log
I had emptied it. I seriously have researched myself and with Apple support and tried everything... ended up doing a backup and a full wipe and reinstall of the OS and then installed Flash perfectly... then restored my data... 6 hours later with all of that but I am glad it is finally resolved!! Thanks for being patient and trying!!!
No problem. I'm unclear on how it got fixed. What did you do differently since we talked?
Gotcha, thanks for the clarificaiton.
