comparing columns within cfgrid
Aug 31, 2007 Aug 31, 2007
I have 2 queries that populate a third query using cfloop and querynew. The third query, "table1", works just fine. But I am using a java format cfgrid to output "table1". I want to highlight, change color, or something, when the value in one column's row does not match another column's row. Is that possible? How?
Advanced techniques
349
Contributor ,
Sep 03, 2007 Sep 03, 2007
When you say that the 2 queries "populate" a 3rd query are you really meaning to say that you have a query of queries or that your 1st 2 are creating temp tables?
Queries do not "populate" anything. You can populate a table from a query.
Now if you have 2 queries and you want to compare the values, then you will have to put the data into lists or some such where you can actually do a comparison.
Like
<cfif group1[1] EQ group2[1]>
Along those lines.
Sep 04, 2007 Sep 04, 2007
Here's my code:
<cfquery name="qrytl2000" datasource="libl">
SELECT #choose2# FROM tldb70.drmst WHERE dracpy = 05 AND drasts IN (#preservesinglequotes(status2)#) AND (DRASID = '100' OR DRASID = '300')
AND dradsp IN (99981,99982,99991,99992,99993,99994)
</cfquery>
<cfset table1 = querynew("tl2000drivercode,tl2000drivername,tl2000fleet,tl2000status,sqldrivercode,sqldrivername,sqlfleet,sqlstatus","varchar,varchar,integer,varchar,varchar,varchar,integer,varchar")>
<cfloop query="qrytl2000">
<cfset addrow = queryaddrow(table1,1)>
<cfset driverset = querysetcell(table1,"tl2000drivercode",qrytl2000.dradrv)>
<cfset nameset = querysetcell(table1,"tl2000drivername",qrytl2000.dranam)>
<cfquery name="qrysql" datasource="timeoff">
SELECT #choose# FROM dbo.log_status WHERE drivercode = '#trim(qrytl2000.dradrv)#'
</cfquery>
<cfset driverset2 = querysetcell(table1,"sqldrivercode",qrysql.drivercode)>
<cfset nameset2 = querysetcell(table1,"sqldrivername",qrysql.drivername)>
<!---This section is for the Fleet number from TL2000. JP--->
<cfif isDefined("qrytl2000.dradsp") AND #qrytl2000.dradsp# NEQ "">
<cfset fleetset = querysetcell(table1,"tl2000fleet",qrytl2000.dradsp)>
<cfset fleetset2 = querysetcell(table1,"sqlfleet",qrysql.fleet)>
<cfelse>
<cfset fleetset = querysetcell(table1,"tl2000fleet","")>
<cfset fleetset2 = querysetcell(table1,"sqlfleet","")>
</cfif>
<!---This section is for the Driving Status from TL2000. JP--->
<cfif isDefined("qrytl2000.drasts") AND #qrytl2000.drasts# NEQ "">
<cfset statusset = querysetcell(table1,"tl2000status",qrytl2000.drasts)>
<cfset statusset2 = querysetcell(table1,"sqlstatus",qrysql.drivingstatus)>
<cfelse>
<cfset statusset = querysetcell(table1,"tl2000status","")>
<cfset statusset2 = querysetcell(table1,"sqlstatus","")>
</cfif>
</cfloop>
<cfformgroup type="horizontal">
<cfgrid name="details" query="table1" format="applet" colheaderbold="yes" colheaderalign="center" rowheaders="no" griddataalign="center" height="650" width="1200">
<cfif #table1.sqlstatus# NEQ #table1.tl2000status#>
<cfgridcolumn header="TL2000 PTO Code" name="tl2000drivercode" bgcolor="##FF3333" dataalign="left" width="120">
<cfgridcolumn header="Database PTO Code" name="sqldrivercode" bgcolor="##FF3333" dataalign="left" width="140">
<cfif isDefined("URL.drivername") AND #URL.drivername# EQ "drivername">
<cfgridcolumn header="TL2000 PTO Name" name="tl2000drivername" bgcolor="##FF3333" dataalign="left" width="200">
<cfgridcolumn header="Database PTO Name" name="sqldrivername" bgcolor="##FF3333" dataalign="left" width="200">
</cfif>
<cfif isDefined("URL.fleet") AND #URL.fleet# EQ "fleet">
<cfgridcolumn header="TL2000 Fleet" name="tl2000fleet" bgcolor="##FF3333" width="100">
<cfgridcolumn header="Database Fleet" name="sqlfleet" bgcolor="##FF3333" width="100">
</cfif>
<cfif isDefined("URL.status") AND #URL.status# EQ "status">
<cfgridcolumn header="TL2000 PTO Status" name="tl2000status" bgcolor="##FF3333" width="140">
<cfgridcolumn header="Database PTO Status" name="sqlstatus" bgcolor="##FF3333" width="140">
</cfif>
<cfelse>
<cfgridcolumn header="TL2000 PTO Code" name="tl2000drivercode" dataalign="left" width="120">
<cfgridcolumn header="Database PTO Code" name="sqldrivercode" dataalign="left" width="140">
<cfgridcolumn header="TL2000 PTO Name" name="tl2000drivername" dataalign="left" width="200">
<cfgridcolumn header="Database PTO Name" name="sqldrivername" dataalign="left" width="200">
</cfif>
<cfgridcolumn header="TL2000 Fleet" name="tl2000fleet" width="100">
<cfgridcolumn header="Database Fleet" name="sqlfleet" width="100">
</cfif>
<cfgridcolumn header="TL2000 PTO Status" name="tl2000status" width="140">
<cfgridcolumn header="Database PTO Status" name="sqlstatus" width="140">
</cfif>
</cfif>
</cfgrid>
</cfformgroup>
How can I compare the individual rows of data between the columns; ie, tl2000drivercode compared with sqldrivercode to see if they match or not?
Documentation
