I am writing help content for software that has two essential components - one web-based and the other a locally installed app (our users work in both). I need the help documentation to be available from both and I wanted to use the new responsive HTML5 layout to make it accessible from a PC, tablet or smartphone while publishing from a single source, but the locally installed app allows users to work offline so I need the help to also be accessible when a user works offline. Is this covered with responsive HTML5 publishing or do i need to publish the documentation to an application help viewer as well?
I apologize if there is an obvious answer to this. I am new to this and I have already checked the RoboHelp user guide and the FAQ and forum to try and find the answer.
Thanks for your help.
Cat
Hi there
Most generally output such as Responsive is stored somewhere on a web server. That means that if the user is offline, they won't be able to access it.
If there is an app, that means they have to download and install it in some way, no? So you would need to find a way to package the help for the app along with the app so it is installed at the same time as the app.
Hopefully this clears the water a tad... Rick
Thank you, Rick. That does help. My goal, if possible, was to try to publish to one output but I'll just do two.
So if I create an application help-type project, which output type is right for a help viewer that can be installed locally with the app?
Much appreciated,
Cat
As my dear friend Peter Grainge would say...
How long is a piece of string?
And the answer, of course, is "it depends". Depends on the app and on the device. If it's a desktop, perhaps a CHM file. But if it's a tablet of some sort, perhaps some form of app packager or something. Maybe Willam, Peter or John will know and pop in to advise.
Cheers... Rick
What devices and o/s are you intending to install the help on? Most of them already have browsers installed, so getting the help output compiled into some form of installation package may be all that’s needed. Perhaps the developers can bundle it with the app?
Hi Jeff,
The app is available on PC, Android phones, and iOS phones and tablets. Bundling it with the app is an ideal way of doing it because updates can get pushed along with new versions. If it's bundled with the app, does it need to be in CHM? And is an Application Help project the type of project I need to open for this type of publishing?
Thanks to all for your help!
CHM is pretty ancient technology – I’d be experimenting with seeing how your HTML5 output works on each of those platforms
Hi there
While I agree with Jeff that CHM is a bit long in the tooth, it's still extremely viable. The only real issue with it is that it's PC only. Specifically, Microsoft Windows PC only. So that rules out Android and other platforms.
Yeah, HTML 5 is like the cool new kid on the block that doesn't play by the regular rules. But also like that same kid, it is a bit unpredictable. If it were me, I'd maybe experiment with WebHelp. ESPECIALLY if you have a fondness for customizing the look and feel of things. WebHelp customizations are so much easier to implement than the HTML 5 stuff in RoboHelp. I'd rather be forced to stick red hot needles into my eye sockets than to have to deal with that type of customization in RoboHelp. Not to mention needing to have a really good grasp of CSS and HTML 5 coding as well as RoboHelp Widgets. There are probably fewer than ten folks on this planet that can easily handle this.
Cheers... Rick
HTML5 help always requires a browser to be viewed. But that doesn't mean it can't be installed locally.
I see three ways of getting it locally (at least for Android):
As an alternative, allow me to suggest the following:
This way the user has basic help in the app at all times. They will only require an internet connection if they want the full help.
Kind regards,
Willam
