1. Re: Control Shift Z in Illustrator not working...
Jacob Bugge Nov 17, 2014 2:43 AM (in response to Owietron)owietron,
It may be time for the list.
The following is a general list of things you may try when the issue is not in a specific file (you may have tried/done some of them already); 1) and 2) are the easy ones for temporary strangenesses, and 3) and 4) are specifically aimed at possibly corrupt preferences); 5) is a list in itself, and 6) is the last resort.
If possible/applicable, you should save curent artwork first, of course.
1) Close down Illy and open again;
2) Restart the computer (you may do that up to 3 times);
3) Close down Illy and press Ctrl+Alt+Shift/Cmd+Option+Shift during startup (easy but irreversible);
4) Move the folder (follow the link with that name) with Illy closed (more tedious but also more thorough and reversible);
5) Look through and try out the relevant among the Other options (follow the link with that name, Item 7) is a list of usual suspects among other applications that may disturb and confuse Illy, Item 15) applies to CC, CS6, and maybe CS5);
Even more seriously, you may:
6) Uninstall, run the Cleaner Tool (if you have CS3/CS4/CS5/CS6/CC), and reinstall.
2. Re: Control Shift Z in Illustrator not working...
Owietron Nov 20, 2014 8:08 PM (in response to Jacob Bugge)Thanks for the reply, after a fresh reinstall and comp restart it works just fine! Seriously glad to have that shortcut back.
3. Re: Control Shift Z in Illustrator not working...
Jacob Bugge Nov 21, 2014 2:07 AM (in response to Owietron)You are welcome, Owietron.
