Hello
I'm new to Robohelp (I've been a long term user of Framemaker for print publications).
The Ebook generation from the Single Source Layout pod has stopped working and I get this message: Internal error encountered, Failed to generate eBook (Robohelp 11 eBook preprocessor 11.0.0.179)
Compiling G:\Development\Course Development\CONE-online\Characteristics-of-light\Robohelp\Characteristics-of-light\Characteristics of light\!SSL!\eBook\!epub_tmp_folder_0\Characteristics_of_light.epub ...
Preparing to create eBook...
Clearing output folder...
Preparing files for eBook...
Copying files...
Updating files...
Finished preparing in 4 sec(s)
Initializing compiler...
Generating eBook output - eBook Handler (11.0.2.240)...
Transforming XHTML topics...
Preparing XHTML topic "Questions_about_light.xhtml"...
Preparing XHTML topic "The_Electromagnetic_Spectrum.xhtml"...
Preparing XHTML topic "Using_wave_properties/Interferometry.xhtml"...
Preparing XHTML topic "Using_wave_properties/Mach-Zehnder_modulators.xhtml"...
Preparing XHTML topic "Using_wave_properties/The-wave-properties-of-light.xhtml"...
Preparing XHTML topic "Wavelengths_and_Frequencies_in_optical_networks/ITU_bands.xhtml"...
Preparing XHTML topic "Wavelengths_and_Frequencies_in_optical_networks/Light_sources_and_wavelengths.xhtml"...
Preparing XHTML topic "Wavelengths_and_Frequencies_in_optical_networks/Wavelengths_and_Frequencies_in_fibre_optics.xhtml"...
Preparing Table of Content...
Generating EPUB 3 output...
EPUB 3 output generation failed.
Internal error encountered, Failed to generate eBook.
Could anyone give me any advice on what to do to fix it? What have I done? I did try installing Adobe Dig Eds 4 and it seemed to stop working after that, but I've tried uninstalling that and it still does the same. I also tried re-installing TCS5. The responsive HTML5 output still works ok.
Thanks in advance,
Sarah
It might be a longshot, but try moving the project to a location where the path is shorter. I had a similar problem (I believe I received the same error message a few months ago, but I can't be 100% certain), where the epub failed to generate, and i tried moving my project to another location where the path to the files was shorter. This resolved the issue for me.
Hi Sue
Many thanks for that!!
I have moved it and it does now work..... and yes the path was very long, buried away in a lowly test directory even before RH then does its generation thing and buries stuff further.
Appreciate your help
FYI – best practices have long recommended that your work should be in “c:\projects\project_name\”
Hi Jeff
Thanks for that. I should have guessed, but wasn't thinking as just messing about with test files. My poor C drive is already under strain these days with other stuff, like Storyline, that loves to be there and all that syncing to the cloud. Oh well.
