dear all,
In FlashBuilder 4.7 (beta + release), it consistently happens that linked assets aren't (re)loaded when compiling. Cleaning the project doesn't seem to help. Restarting FB, then cleaning + building mostly reloads the assets.
Is there a way to (manually?) clean all caches, the way a restart of FB does?
This question could be related to: http://forums.adobe.com/message/4809438#4809438 and http://forums.adobe.com/message/2921124#2921124
This seems reproducible:
1. Make 'assets.fla' file in Flash Professional, create one symbol with some random graphics, ActionScript Linkage Class set to 'SomeGraphicAsset', publish to 'assets.swf'
2. In Flash Builder 4.7, create new ActionScript Mobile project
3. Make new Class "SomeGraphic", link with previously created graphics in Flash:
package
import flash.display.MovieClip;
[Embed(source="/../embedded-assets/assets.swf", symbol="SomeGraphicAsset")]
public class SomeGraphic extends MovieClip
public function SomeGraphic()
super();
4. In constructor of entry-point class for project add:
var somegraphic:SomeGraphic = new SomeGraphic();
this.addChild(somegraphic)
5. compile / debug project
6. open 'assets.fla' in Flash Pro. Change something to the 'SomeGraphicAsset' symbol. Publish to .swf file.
7. In Flash Builder, debug -> shows old file without updated graphics
8. In Flash Builder, clean project, debug -> shows old file without updated graphics
9. Close Flash Builder, reopen Flash Builder, clean project, debug -> mostly the updated graphics show.
Any feedback to make this more workable, or a way to fully flush all caches in FB are greatly appreciated.
It's crazy having to close / open FB every time a graphical asset changes in your project.
- this has been tested on 2 different Mac OSX 10.8.x computers, FlashBuilder 4.7 AIR SDK 3.5
- sample project can be downloaded here: http://dl.dropbox.com/u/608333/AssetProblemSampleProject.zip
hoping for some feedback,
Bart
Still no solution for this?
I have exactly the same problem. It also happens with .swc files added to the library path, and with external source folders - it's just a nightmare trying to get FB 4.7 to pick up any changes!
This is absolutely killing me too. I have to switch back to 4.6 tonight as 4.7 has really screwed my workflow up completely.
New assets are not getting copied over, some folders are just randomly ignored, and to top it off, now my project won't even build:
http://forums.adobe.com/thread/1127639?tstart=0
Is anyone from Adobe even listening around here?
Ya I'm getting the same. Anyone find a workaround yet? This is killing the workflow.
Bump, this is really annoying...
Anyone found a work-around to this? Its pretty fundemental..
this issue also happen with ANE, workaround for this is hit clean up button (make sure you close Flash Player before doing cleanup or it will blocked over wirte swf by OS)
Same problem.
Just upgraded from FB4.6 on Win7 to FB4.7 (build 349722) on a new MacBookPro.
We have 20-30 .swc files that contain art which are merged into code. When I change the contents of a swc it is really difficult to get FB to refresh and pick up the changes. Building clean, hitting refresh on the project or lib directory. Restarting FB then building clean seems to help. On FB4.6 Windows, we always had to build clean, but not restart all of FB...
I followed a post about setting global swc cache off, but that did not seem to help either.
http://forums.adobe.com/message/5010103
This is killing my workflow - any help would be appreciated.
Mac OSX 10.8.4
Google Chrome Version 27.0.1453.116
Flash Player 11,7,700,203 installed (debug version)
Any progress with that issue? It is getting really annoying now...
Come on Adobe, at least PRETEND like you give a shit.
This is screwing with our workflow too. Getting really sick of manually copying in my TexturePacker Spritesheets into bin-debug because FlashBuilder is too stupid to realize something has changed...
Adobe, 10 months since this original post with no reply and no fix. I just restructured the files on a nearly done app in Fb 4.7 and now I'm out of business. Can't compile because Fb can't find my files. Nothing that I type in the Embed path works.
You guys need to get in the game or get out. Tell all of your faithful developers that you just aren't going to commit to fixing major bugs; that we can't select movies from the Gallery Picker; that it's 2013 and your mobile development environment doesn't have a calendar control. That you've punted GPU and GUI forms to outside developers. I just subscribed to Creative Cloud and I'm pissed that the environment is such a half ass effort. It's almost great but almost doesn't cut it. Do the work!
It's death by a thousand paper cuts.
I'm facing this problem too and I use following workaround (still looking for a real solution):
It's just a workaround ... but it works for me (and I hope for you all).
Regards
Parantido
p.s.: sorry for my really bad english.
I am having the exact same problem. Looking in the Project properties > Actionscript Build Packaging > Package contents - only a handfull of the external assets are listet (not referenced in the code as they are loaded by data files)
Here's an example.
Folder contents:
http://cl.ly/image/102W1F3E2H1b
What Flash Builder thinks is in the folder:
I've stopped using Flash Builder and moved to IntelliJ IDEA just because of this issue. I no longer need a Creative Cloud membership for myself. It's too bad cause I generally liked Flash Builder, but very glad I made the switch. However, I still have programmers using Flash Builder so this problem is still impacting me. I wish Adobe would step up and address the issue, or they will lose more of my money.
This issue is a serious problem for me too. It's no good not knowing if your assets will be included in in the final release build.
I Have the same issue!!! I have been working with FlashDeveloper without problems and now it not possible work with Flash Builder, Please SOLVE IT!
In the end I managed to work around this issue by dropping Flash Builder and moving to Intelligj. It's a shame that Adobe can't maintain the software that they have charged people for.
Having the same problem. This is very basic and completely sloppy for a professional IDE. This needs to be fixed yesterday.
Sorry for reviving such an old thread, but I've been having this same issue up until now, and it's starting to get under my skin, with a single image on my project that won't update for NOTHING I do. The pathname is right, but the image that shows up is one that USED to be there but was changed. I propose we do something about this, to get Adobe's attention, staying silent won't help it. Did someone get to submit a bug report?
I'm having the same problem. I will try the workaround now, but yes, it's really sad to have NO FEEDBACK but paying for CREATIVE CLOUD Memberships (I have 4).
Parandito's solution worked for me for a couple of times, but that now seems to have stopped working.
Opening/closing project, cleaning, etc.. No avail.
I am trying to create a release build for an Android project where I am including SWFs as assets.
The SWF files are not under any circumstance being included. Any possible solutions?
I have the same problem as well. I created a new workspace and imported my other projects in. That worked for a while. Then it stopped. Now I have to clean some of my projects before each build. Others continue to work. Recently I came across this problem. None of my changes were showing up in package content. I put them under an existing folder and it seemed to work. I think dragging files into and out of the project through Flash Builder Package Panel might trigger some process. Of course if you update the files outside of Flash Builder remember to Refresh the root project folder so it sees it. I was going to say it's unbelievable that the Adobe Flash managers whoever they are would leave this problem so long but it's not unbelievable.
sometimes I manually delete the bin-debug folder which seems to help.
Also, I've had issues with getting flash builder to recognize a change in files (say SWFs, SWCs) that are outside the current project's folder (like a lib folder or a folder shared between multiple projects). My solution was to copy the resource files into the project's folder.
I gave up waiting on a FB fix... Thanks Adobe and your legendary support...
I recommend you change your embedded asset strategy:
(1) create your assets as linked MCs in your FLA, have no code in there, compile it to swf.
(2) Add this singleton to your project:
package com.tamere
import flash.display.Loader;
import flash.display.Sprite;
import flash.events.Event;
import flash.events.EventDispatcher;
import flash.events.IOErrorEvent;
import flash.events.ProgressEvent;
import flash.net.URLRequest;
import flash.system.ApplicationDomain;
import flash.system.LoaderContext;
public class Skin extends EventDispatcher
private static var instance:Skin;
private var loader:Loader;
private var applicationDomain:ApplicationDomain;
public function Skin(pvt:Enforcer)
loader = new Loader();
loader.contentLoaderInfo.addEventListener(ProgressEvent.PROGRESS, function(event:ProgressEvent):void{
dispatchEvent(event);
loader.contentLoaderInfo.addEventListener(Event.COMPLETE, function(event:Event):void{
applicationDomain = loader.content.loaderInfo.applicationDomain;
loader.contentLoaderInfo.addEventListener(IOErrorEvent.IO_ERROR, function(event:IOErrorEvent):void{
public static function getInstance():Skin
if ( instance === null ) instance = new Skin(new Enforcer);
return instance;
public static function load(theme:String, systemPath:String):void
instance.loader.load(new URLRequest(systemPath+theme+".swf"));
public static function getSprite(ref:String):Sprite
trace("[Skin] ~", ref);
return new (getInstance().applicationDomain.getDefinition(ref) as Class);
class Enforcer {}
(3) In your Main app constructor, load the external swf skin:
// load skin
Skin.getInstance().addEventListener(ProgressEvent.PROGRESS, function(event:ProgressEvent):void{
progressBar.updateProgress(event.bytesLoaded/event.bytesTotal);
Skin.getInstance().addEventListener(IOErrorEvent.IO_ERROR, function(event:IOErrorEvent):void{
TweenMax.to(progressBar, .5, {autoAlpha:0});
TweenMax.to(spinner, .5, {autoAlpha:0});
displayError(ErrorDisplay.ERROR_CONNECTION, "007");
Skin.getInstance().addEventListener(Event.COMPLETE, function(event:Event):void{
skinLoaded = true;
if ( assetsLoaded ) start(); // YOUR PROGRAM IS READY TO START
Skin.load("skin-player-default", stage.loaderInfo.url.slice(0, stage.loaderInfo.url.lastIndexOf("/") + 1));
(4) Now your assets are ready to use, see an example of constructor
public function VideoPlayerNav()
skin = Skin.getSprite("com.adobeniquesamere.VideoPlayer");
addChild(skin);
playPauseBtn = skin.getChildByName("playPauseBtn") as PlayPauseBtn;
stopBtn = skin.getChildByName("stopBtn") as RewindBtn;
fullScreenBtn = skin.getChildByName("fullScreenBtn") as FullScreenBtn;
volumeScroller = skin.getChildByName("volumeScroller") as VolumeScroller;
videoScrollBar = skin.getChildByName("videoScrollBar") as VideoScrollBar;
timeStamp = skin.getChildByName("timeStamp") as VideoTimeStamp;
bg = skin.getChildByName("bg") as Sprite;
hotSpot = skin.getChildByName("hotSpot") as Sprite;
// ... continue with your constructor implementation ...
I have used this method on very large scale websites, it works GREAT! Hope that helps!
P.S. Anyways Flash is dead, they say, go learn something new!
