Could you be more specific about what you're checking as you
see it on YOUR system?
Also check all the other things mentioned in that thread as
well. There are so many variables involved in each machine's sound
setup that I cannot even guess what might be causing the problem at
this point .
Also, AS A TEST, it would be interesting to know if issue
happens to Flash Player plug-in running in NON IE browsers. IE is
the only browser that uses the Flash Player ActiveX control.
Everything else uses the plugin. To test, install Firefox (
http://www.mozilla.com/en-US/firefox/)
and install the Flash Plugin from Adobe.com.
Note that I'm not proposing you -switch- browsers. Just that
you test to see if you get the same behavior in the Flash Player
plugin as the ActiveX control.
But of course, if you -wanted- to switch you could..
