6 Replies Latest reply: Nov 20, 2014 5:02 PM by Gespinha RSS
    DropDownList value selected by default?
    Gespinha Community Member
      Hi there,
      I've got the following DropDownList, but it gets rendered with no options selected. How can I make ''one" the default option for this element?
      var w, layout;
      layout = "dialog {  \
          dropdown: DropDownList { \
              properties: { \
                  items: ['one','two','three'] \
      w = new Window(layout);
      w.show();
        • 1. Re: DropDownList value selected by default?
          Philip Cord Community Member
          You just have to set the selection, example.
          var w, layout;
                  properties: { \
          w.dropdown.selection=0;
          w.show();
          • 2. Re: DropDownList value selected by default?
            JJMack Community Member
            You need to default one. I your case 0, 1 or 2.  I don't know Photoshop ScriptUI only steal other UI example and modify for my application.   Here how a made font select-able note I set dd1 selection to 1 dd1 could also be change by remembering the previous run  and changing dd1 prior to displaying the dialog.
                dlg.msgPnl.grp6a =dlg.msgPnl.add('group');
                dlg.msgPnl.grp6a.orientation='row';
                dlg.msgPnl.grp6a.alignment='fill';
                dlg.msgPnl.grp6a.st1 = dlg.msgPnl.grp6a.add('statictext',undefined,'Font');
                fontlist = new Array();
                    for (var i=0,len=app.fonts.length;i
                    fontlist[i] =  app.fonts[i].name;
              dlg.msgPnl.grp6a.dd1 = dlg.msgPnl.grp6a.add('dropdownlist',undefined,fontlist);
              dlg.msgPnl.grp6a.dd1.selection=1;
            • 3. Re: DropDownList value selected by default?
              Thanks, that worked
              Btw, how do I return the value that is selected?
              For example, I change the dropdown to 'three' and I want it to return to me the number of the selected option.
              • 4. Re: Re: DropDownList value selected by default?
                There are various ways here is one way to show the value when it is changed.
                var w, layout;
                        properties: { \
                w.dropdown.onChange= function(){
                    alert(w.dropdown.selection.text);
                w.show();
                • 5. Re: DropDownList value selected by default?
                  csuebele CommunityMVP
                  The drop down list will show either the text or a number. with processing the result from a dropdownlist, you want to make sure you specify what you want or you will run into issues. To get the number of the selection you would werite:
                  alert(parseInt(w.dropdown.selection))
                  • 6. Re: DropDownList value selected by default?
                    Thanks guys it worked
