2 Replies Latest reply: Nov 20, 2014 8:06 PM by JJMack RSS
    Make EditText only allow numbers?
    Gespinha Community Member
      Hi there,
      I am trying to make an EditText only allow to input numbers, how can I create this on the following EditText field?
      var w, layout;
      layout = "dialog {  \
          text_field: EditText { \
      w = new Window(layout);
      w.show();
        • 1. Re: Make EditText only allow numbers?
          xbytor2 Community Member
          Check out the Contact Sheet II.jsx script that comes with PS. It has key filtering stuff in it. Ignore the stuff for handling the Enter key: it's there to validate the form before processing.
          • 2. Re: Make EditText only allow numbers?
            JJMack Community Member
            X is an extremely talented Photoshop scripter where I'm just a hacker that just hacks small scripts to do what I want done.   I created a small script a while back  to tile images onto a canvas. Data required is numeric.   I don't know Photoshop ScriptUI and those that do are annoyed at Adobe for not fixing bugs they report.  So I just steal their dialogs and smash them into what I want.and  hopefully avoid the bugs.  When I  create the dialog it would accept any values. I wanted to allow only numeric data so after doing some searching I think if i remember correctly I found some code I believe Michael Hale posted to handle the keyboard. I added that code to my small script.  You may have a easier time find our how to do what you want to do looking at a small script.   Contact Sheet II.jsx is huge.  How things fit may be harder to see in there. http://www.mouseprints.net/old/dpr/PasteImageRoll.jsx  If the uses enter anything other the a number or . and some edit keys like backspace in a numeric files they receive a beep and the key is not accepted.
