0 Replies Latest reply: Nov 20, 2014 6:07 PM by dointsdf RSS
    Premiere Pro CC crashes upon XML import from Final Cut 7 Export
    dointsdf
      Hello all,
      I have recently tried to import a FCP7 XML into Premiere Pro CC 2014, and a few seconds after initiating the export Premiere Pro crashes. Any solution to this???
      I Exported on a Mac Tower running FCP7 and then imported the XML on a PC Running the latest Premiere CC v8.1. Could that be a problem in itself?
      Also I'm considering a workaround where I move the FCP7 to FCPX, generate the XML then try importing again. Worth a shot?
      Also trying this strictly on an Apple computer to import and save before moving to my main PC station. Thoughts?
      The sequence I'm trying to import is fairly massive too, not sure if this is why, but it is mult-layered, both in audio and video and is running about an hour in length with several other blocks of video files after that, probably running up to 2 hrs. This should not be a problem, right?
      Help! It would be greatly appreciated to get out of the clutches of final cut finally.
