SUBJECT: How create results with an Outer Join using 2
different databases
ISSUE:
I'm working with existing functionality, so I need to work
this code in somehow or rewrite a significant amount of code.
I am using tables that come from different datasources.
I can't use the outer join with QofQ, right? I need to use an
outer join to combine two result sets that don't have same
number of matches.
GOAL:
I want to end up with final results so that any record from
qdocSourceSort with a fac_ID value has its sourceTitle field
populated with the sourceTitle created in qqFacTitle.
(qdocSourceSort already has the fac_id NULL value records
populated with SourceTitle values.)
My main objective is to sort all these records by
SourceTitle!
CODE:
The two tables I need to combine are qdocSourceSort and
qqFacTitle below. (qqSourceFacNo (below) is an intermediate step.)
I want all these records:
<cfquery name="qdocSourceSort"
datasource="#request.peds#">
select *
from PEdocs, Sources
WHERE deleted IS NULL
and UPPER(docLetter) = <CFQUERYPARAM
value="#attributes.letter#" cfsqltype="CF_SQL_CHAR"
maxlength="1">
and fk_sourceID = sourceID
</cfquery>
I want to combine the results above with the last query of
the two below.
<cfquery dbtype="query" name="qqSourceFacNo">
select sourceFacID
from qdocSourceSort
where sourceFacID IS NOT NULL
</cfquery>
<cfquery name="qqFacTitle"
datasource="#request.generalds#">
select fac_ID, fac_Facility AS sourceTitle
from IHSFacility
where fac_ID IN (#ValueList(qqSourceFacNo.sourceFacID)#)
</cfquery>
qqFacTitle.fac_ID would match some of the
qdocSourceSort.fac_ID values. The rest of the qdocSourceSort.fac_ID
values would
be NULL.
Also numerous qdocSourceSort.fac_ID values could be the same
number, so each result from qqFacTitle.fac_ID needs to be
matched as many times as it is referenced in
qdocSourceSort has a column SourceTitle, so each result of
qqFacTitle.SourceTitle needs to be merged into the SourceTitle
fields in a qdocSourceSort record wherever
qqFacTitle.fac_ID matches qdocSourceSort.fac_ID.
Can anybody help me?!?!?
Thanks.
