Show 2 replies
1. Re: how many frames is the average animated card
rezun8 Nov 21, 2014 1:46 PM (in response to jenni4nagy)people will go back and forth on this issue, I personally like to run 30 but depending on how in-depth your animation is, what all it os doing you can get away with a lower fps. I would recommend not going below 18 as the animation can start to look choppy.
best of luck
2. Re: how many frames is the average animated card
Ned Murphy Nov 21, 2014 1:49 PM (in response to jenni4nagy)The fps can be whatever you prefer - 24 versus 30 ... either is fine.
I doubt you will be getting an answer regarding the average number of frames in a card animation. Animations can vary between 1 (code based)) and thousands of frames.
If you give a description of the animation you intend to create a guesstimate might be possible
