Troubleshoot Update Errors
Many update errors are caused by missing or modified files required by Photoshop, typically by a disk cleanup utility (Ex: CleanMyMac, MacKeeper, etc). Make sure you have the latest updates for your clean-up utilities or discontinue use.
Explanations of error codes:
U = Updater.
44 = Install Update Error
M1 = Automatic
M2 = Standalone mode
P = Patcher
6 = Done With Errors
7 = Installation Failed
ISSUE: Installation failed. Error Code: U44M1P7, U44M2P7, U44M1P6
SOLUTION: Run the installer. Reinstall Photoshop CS6 to repair/replace the missing/modified file. Select Help>Updates… to run the updater again. http://helpx.adobe.com/creative-suite/kb/error-u44m1p7-installing-updates-ccm.html
