1 Reply Latest reply: Nov 23, 2014 8:14 AM by BKBK RSS
    cfdocument invalid token format pdf
    Karolus Community Member
      I keep getting this error:
      Here is the whole tag:
      <cfdocument
          format = "PDF"
          backgroundVisible = "no"
          filename = "test.pdf"
          localUrl = "yes"
          marginBottom = "1"
          marginLeft = "1"
          marginRight = "1"
          marginTop = "1"
          mimeType = "text/plain"
          name = "Test"
          orientation = "portrait"
          overwrite = "yes"
          pageType = "letter"
          permissions = "AllowPrinting,AllowCopy"
          permissionspassword = "password to access restricted permissions"
          saveAsName = "Test2"
          unit = "in">
      Any advice is very welcome.
      Karolus
        • 1. Re: cfdocument invalid token format pdf
          BKBK Community Member
          A first guess is that it has to be something other than the attribute, format = "PDF", as that is frequently trodden ground. To debug this, start with the following, simpler code:
          <cfdocument
              format = "PDF"
              filename = "test.pdf"> Some text </cfdocument>
          If it fails, then the likely cause is that Coldfusion is unable to access the directory /CFIDE/scripts/. If works, then continue adding attributes, one by one, and testing.
