1. Re: Project Manager fails to trim after new "Consolidate & Transcode" method
Trent Happel Nov 22, 2014 4:09 PM (in response to Dslyecxi)You are receiving this warning as the selected Format (DNxHD MXF OP1a) does not support your combination of frame size, frame rate and field combination. For example, DNxHD will support frame sizes 1280x720 or 1920x1080, whereas your source file is 1280x800.
Try using a Format/Preset combination that will support your source file parameters. For example: ProRes Match Source (Mac) or CineForm Match Source (Mac and Windows).
Hope this helps.
2. Re: Project Manager fails to trim after new "Consolidate & Transcode" method
Dslyecxi Nov 22, 2014 8:54 PM (in response to Trent Happel)Thanks, that does help explain what's happening here. My follow-on question would be - what was Premiere using in the past that automatically handled this? I see that you can use other presets beyond the defaults listed - is there any particular method or preset that was employed prior to this change? Which is to say - is there something I can use that will get me the same end result, without it needing to become a .mov in the process?
3. Re: Project Manager fails to trim after new "Consolidate & Transcode" method
Trent Happel Nov 22, 2014 9:41 PM (in response to Dslyecxi)The previous Trim option had limited .mov and .avi support, that if your codec was supported, you would get the automatic trim. For Consolidate and Transcode you could create a custom preset in Export Settings or AME using the codec of your source file (hold down Opt/Alt when clicking on Save Preset button to export a preset). Make sure your codec parameters (frame size, frame rate, PAR, fielding) match your source file and Sequence. Open Project Manager and click the Import Preset button to import your custom preset. In your case you would set Match: to Sequence or Preset (Match: Individual Clips will only support Match Source presets, which is supported for only some codecs). I'm hoping this would work for you.
4. Re: Project Manager fails to trim after new "Consolidate & Transcode" method
Dslyecxi Nov 22, 2014 9:48 PM (in response to Trent Happel)Thanks, that's sorted it out for me.
