3 Replies Latest reply: Nov 23, 2014 1:44 PM by romanobstuder RSS
    InDesign Script select Page and Layer
    romanobstuder Community Member
      Hi all
      I need to select all graphics on a page, but only on a given layer.
      myDocument.pages[myPageCounter].allGraphics.length
      This works fine.
      myDocument.pages[myPageCounter].layers.itemByName("[myLayerName]")
      As soon as I try to bring in the layer into this I fail.
      Appreciate any hints
      Regards
      Romano
      Some more context...
      myLabelStyle = myDocument.paragraphStyles.item(myLabelStyleName);
      mySwatch = myDocument.swatches.item(mySwatchName);
      myLayer = myDocument.layers.item(myLayerName);
      if (myConfirmation == true){
              for(var myPageCounter = 0; myPageCounter < myDocument.pages.length; myPageCounter ++){
                  $.writeln("The current page counter = " + myPageCounter);
                  for(var myGraphicsCounterPerPage = 0; myGraphicsCounterPerPage < myDocument.pages[myPageCounter].layers.itemByName("[myLayerName]"), allGraphics.length; myGraphicsCounterPerPage ++){
                      $.writeln("The current graphics counter per page = " + myGraphicsCounterPerPage);
                      myGraphics = myDocument.pages[myPageCounter].allGraphics;
                      myAddLabel(myDocument, myGraphics[myGraphicsCounterPerPage], myGraphicsCounterPerPage, myLabelType, myLabelHeight, myLabelOffset, myLabelStyle, mySwatch, myLayer, myStoriesArray);
        • 1. Re: InDesign Script select Page and Layer
          jugganaut Community Member
          Have you created your layer?
          I had this issue before and as long as there's nothing else on the layer, you could use:
          var layerCount = myLayer.pageItems.length;
          • 2. Re: InDesign Script select Page and Layer
            Jump_Over Community Member
            Since layer.parent is a document (not a page) ==> better way is to set a goal like:
            "I need to select all graphics on a LAYER, but only on a given PAGE".
            So iterate through thisLayer.allPageItems and check if its parentPage property is equal to thisPage.
            Finally do some job with pageItems which passed this filter through.
            Jarek
            • 3. Re: InDesign Script select Page and Layer
              did a bit more coding
              I now get all the graphics on a given page, then test every single graphic if it is on my specific layer.
              I place all graphics with the correct condition in an array and pass the array on to the next function
              Romano
              function myAddLabels(myDocument, myLabelType, myLabelHeight, myLabelOffset, myLabelStyleName, mySwatchName, myLayerName){
                  myStoriesArray = new Array();
                  if (app.selection.length == 0){ // If nothing is selected apply caption to all graphics in the document
                      var myConfirmation = confirm("Add captions to all images in the document?", false, "LabelGraphics.jsx" );
                          var myGraphics = myDocument.allGraphics;
                  else{ // If graphics are selected, just add captions to the selected items, as long as they are rectangles(image frames)
                      var myConfirmation = true;
                      var mySelections = app.selection;
                      myGraphics = new Array();
                      for(i = 0; i < mySelections.length; i++){
                          if(mySelections[i] == "[object Rectangle]"){   //Check to make sure selection only includes rectangles
                              myGraphics.push(mySelections[i].allGraphics[0]);
                          else{
                              //alert("Objects other than graphics were selected!");
                              //Nothing happens if you don't select at least one graphic
                          var myTest = myLayer.allGraphics.lenght;
                          $.writeln("myTest = " + myTest);
                          for(var myGraphicsCounterPerPage = 0; myGraphicsCounterPerPage < myDocument.pages[myPageCounter].allGraphics.length; myGraphicsCounterPerPage ++){
                              $.writeln("===============");
                              var myAllGraphics = myDocument.pages[myPageCounter].allGraphics;
                              var myAllGraphicsLength = myAllGraphics.length;
                              $.writeln("myAllGraphicsLength = " + myAllGraphicsLength);
                              for(i = 0; i < myAllGraphics.length; i++){
                                  if(myAllGraphics[i].itemLayer.name == myLayerName){   //Check to make sure selection only includes rectangles
                                      myGraphics.push(myAllGraphics[i]);
                                  else{
                          var myLayersCounterPerPage = myDocument.layers.length;
                          var myGiveMeTheLayersName = myLayer.name;
                          $.writeln("myLayer = " + myLayer);
                          $.writeln("myLayerName = " + myLayerName);
                          $.writeln("myGiveMeTheLayersName = " + myGiveMeTheLayersName);
                          $.writeln("The current layers counter per page = " + myGraphicsCounterPerPage);
                          $.writeln("The current graphics counter per page = " + myLayersCounterPerPage);
                          for(var myGraphicsCounterPerPageA = 0; myGraphicsCounterPerPageA < myGraphics.length; myGraphicsCounterPerPageA ++){
                              myAddLabel(myDocument, myGraphics[myGraphicsCounterPerPageA], myGraphicsCounterPerPageA, myLabelType, myLabelHeight, myLabelOffset, myLabelStyle, mySwatch, myLayer, myStoriesArray);
