1. Re: photos in photoshop opening as a collage of old photos along with fluorescent pink patches. Photos are completely distorted. photo attached
JJMack Nov 22, 2014 7:05 PM (in response to erinlato)I think you may have a display adapter problem or a display driver problem use Photoshop menu help>System Info the use its copy button and paste the info here. That way we will know what hardware and software you using. The image you posted shows little no real information.
2. Re: photos in photoshop opening as a collage of old photos along with fluorescent pink patches. Photos are completely distorted. photo attached
elandr5 Nov 23, 2014 5:20 AM (in response to JJMack)Thank you JJMack, Here is that info:
Adobe Photoshop Version: 2014.2.1 20141014.r.257 2014/10/14:23:59:59 CL 987299 x64
Operating System: Mac OS 10.10.1
System architecture: Intel CPU Family:6, Model:58, Stepping:9 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX
Physical processor count: 4
Processor speed: 2900 MHz
Built-in memory: 24576 MB
Free memory: 12780 MB
Memory available to Photoshop: 23090 MB
Memory used by Photoshop: 70 %
3D Multitone Printing: Disabled.
Windows 2x UI: Disabled.
Highbeam: Enabled.
Image tile size: 1024K
Image cache levels: 4
Font Preview: Medium
TextComposer: Latin
Display: 1
Main Display
Display Bounds: top=0, left=0, bottom=1440, right=2560
OpenGL Drawing: Enabled.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Drawing Mode: Basic
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumCLGPUs=1
glgpu[0].GLVersion="2.1"
glgpu[0].GLMemoryMB=512
glgpu[0].GLName="NVIDIA GeForce GTX 660M OpenGL Engine"
glgpu[0].GLVendor="NVIDIA Corporation"
glgpu[0].GLVendorID=4318
glgpu[0].GLRectTextureSize=16384
glgpu[0].GLRenderer="NVIDIA GeForce GTX 660M OpenGL Engine"
glgpu[0].GLRendererID=16918311
glgpu[0].HasGLNPOTSupport=1
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1638 4]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[2048]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
clgpu[0].CLPlatformVersion="1.2 (Sep 20 2014 22:01:02)"
clgpu[0].CLDeviceVersion="1.2 "
clgpu[0].CLMemoryMB=512
clgpu[0].CLName="GeForce GTX 660M"
clgpu[0].CLVendor="NVIDIA"
clgpu[0].CLVendorID=16918272
clgpu[0].CLDriverVersion="10.0.43 310.41.05f01"
clgpu[0].CUDASupported=0
clgpu[0].CLBandwidth=3.06951e+10
clgpu[0].CLCompute=50.1607
License Type: Subscription
Serial number: 96040838722493636061
Application folder: /Applications/Adobe Photoshop CC 2014/
Photoshop scratch has async I/O enabled
Scratch volume(s):
Startup, 2.73T, 1.15T free
Required Plug-ins folder: /Applications/Adobe Photoshop CC 2014/Adobe Photoshop CC 2014.app/Contents/Required/Plug-Ins/
Primary Plug-ins folder: /Applications/Adobe Photoshop CC 2014/Plug-ins/
Installed components:
adbeape.framework adbeape 3.4.0.29366 0.1160850
AdbePM.framework AdbePM 2.2.00.32695 79.558079
AdbeScriptUIFlex.framework AdbeScriptUIFlex 6.3.2.32394 79.550992
adobe_caps.framework adobe_caps 8.0.0.13 1.248010
AdobeACE.framework AdobeACE 2.20.02.33308 79.557478
AdobeAGM.framework AdobeAGM 4.30.41.33308 79.557478
AdobeAXE8SharedExpat.framework AdobeAXE8SharedExpat 3.8.0.32260 79.551013
AdobeAXEDOMCore.framework AdobeAXEDOMCore 3.8.0.32260 79.551013
AdobeBIB.framework AdobeBIB 1.2.03.33308 79.557478
AdobeBIBUtils.framework AdobeBIBUtils 1.1.01 79.557478
AdobeCoolType.framework AdobeCoolType 5.15.00.33308 79.557478
AdobeCrashReporter.framework AdobeCrashReporter 7.0.1
AdobeExtendScript.framework AdobeExtendScript 4.5.5.32401 79.551519
AdobeJP2K.framework AdobeJP2K 1.2.2.33078 79.254012
AdobeLinguistic.framework 20256
AdobeMPS.framework AdobeMPS 5.8.1.33340 79.557676
AdobeOwl.framework AdobeOwl 5.2.4
AdobePDFL.framework AdobePDFL 11.0.0.33336 79.512424
AdobePDFSettings.framework AdobePDFSettings 1.4
AdobePIP.framework AdobePIP 7.2.1.3399
AdobeScCore.framework AdobeScCore 4.5.5.32401 79.551519
AdobeUpdater.framework AdobeUpdater 6.0.0.1452 "52.338651"
AdobeXMP.framework AdobeXMPCore 79.156797 79.156797
AdobeXMPFiles.framework AdobeXMPFiles 79.156797 79.156797
AdobeXMPScript.framework AdobeXMPScript 79.156797 79.156797
ahclient.framework ahclient 1.8.0.31
aif_core.framework AdobeAIF 2014.0.00 2014.0
aif_ocl.framework AdobeAIF 2014.0.00 2014.0
aif_ogl.framework AdobeAIF 2014.0.00 2014.0
amtlib.framework amtlib 8.0.0.122
boost_date_time.framework boost_date_time 8.0.0.0
boost_signals.framework boost_signals 8.0.0.0
boost_system.framework boost_system 8.0.0.0
boost_threads.framework boost_threads 8.0.0.0
Cg.framework NVIDIA Cg
CIT.framework CIT 2.2.6.32411 155804
CITThreading.framework CITThreading_boost 2.2.6.32411 155804
dvaaudiodevice.framework dvaaudiodevice 8.0.0.0
dvacore.framework dvacore 8.0.0.0
dvamarshal.framework dvamarshal 8.0.0.0
dvamediatypes.framework dvamediatypes 8.0.0.0
dvametadata.framework dvametadata 8.0.0.0
dvametadataapi.framework dvametadataapi 8.0.0.0
dvametadataUI.framework dvametadataUI 8.0.0.0
dvaplayer.framework dvaplayer 8.0.0.0
dvatransport.framework dvatransport 8.0.0.0
dvaui.framework dvaui 8.0.0.0
dvaunittesting.framework dvaunittesting 8.0.0.0
dynamiclink.framework dynamiclink 8.0.0.0
ICUConverter.framework ICUConverter 3.61 "gtlib_3.0" "." "16615"
ICUData.framework ICUData 3.61 "gtlib_3.0" "." "16615"
LogSession.framework LogSession 7.2.1.3399
mediacoreif.framework mediacoreif 8.0.0.0
PlugPlugExternalObject.framework 5.0.0.62
PlugPlugOwl.framework PlugPlugOwl 5.2.0.52
UpdaterNotifications.framework UpdaterNotifications 8.0.0.14 "8.0.0.14"
WRServices.framework
Required plug-ins:
3D Studio 2014.2.1 x001 x003 ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
Accented Edges 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Adaptive Wide Angle 15.2.1, Copyright © 2014 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
Angled Strokes 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Average 2014.2.1 x001 x003 ©1993-2014 Adobe Systems Incorporated - from the file “Average.plugin”
Bas Relief 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
BMP 15.2.1, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Camera Raw 8.7 (309), Copyright © 2014 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
Camera Raw Filter 8.7 (309), Copyright © 2014 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
Chalk & Charcoal 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Chrome 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Cineon 2014.2.1 x001 x003 ©2002-2014 Adobe Systems Incorporated - from the file “Cineon.plugin”
Clouds 2014.2.1 x001 x003 ©1993-2014 Adobe Systems Incorporated - from the file “Clouds.plugin”
Collada DAE 2014.2.1 x001 x003 ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
Color Halftone 15.2.1, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Colored Pencil 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
CompuServe GIF 15.2.1, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Conté Crayon 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Craquelure 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Crop and Straighten Photos 2014.2.1 x001 x003 ©2003-2014 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
Crop and Straighten Photos Filter 15.2.1, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Crosshatch 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Crystallize 15.2.1, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Cutout 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Dark Strokes 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
De-Interlace 15.2.1, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Dicom 15.2.1, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “dicom.plugin”
Difference Clouds 2014.2.1 x001 x003 ©1993-2014 Adobe Systems Incorporated - from the file “Clouds.plugin”
Diffuse Glow 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Displace 15.2.1, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Dry Brush 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Eazel Acquire 2014.2.1 x001 x003 ©1997-2014 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
Embed Watermark NO VERSION - from the file “DigiSign.plugin”
Entropy 2014.2.1 x001 x003 ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
Export Color Lookup Tables 2014.2.1 x001 x003 �2012-2014 Adobe Systems Incorporated - from the file “Export3DLUT.plugin”
Extrude 15.2.1, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
FastCore Routines 2014.2.1 x001 x003 ©1990-2014 Adobe Systems Incorporated - from the file “FastCore.plugin”
Fibers 15.2.1, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Film Grain 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Filter Gallery 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Flash 3D 2014.2.1 x001 x003 ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
Fresco 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Glass 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Glowing Edges 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Google Earth 4 KMZ 2014.2.1 x001 x003 ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
Graphic Pen 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Halftone Pattern 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
HDRMergeUI 15.2.1, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
HSB/HSL 15.2.1, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
IFF Format 15.2.1, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
IGES 2014.2.1 x001 x003 ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
Ink Outlines 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
JPEG 2000 2014.2.1 x001 x003 ©2001-2014 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
Kurtosis 2014.2.1 x001 x003 ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
Lens Blur 15.2.1, Copyright © 2002-2014 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
Lens Correction 15.2.1, Copyright © 2002-2014 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
Lens Flare 15.2.1, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Liquify 15.2.1, Copyright © 2001-2014 Adobe Systems Incorporated - from the file “Liquify.plugin”
Matlab Operation 2014.2.1 x001 x003 ©1993-2014 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
Maximum 2014.2.1 x001 x003 ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
Mean 2014.2.1 x001 x003 ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
Measurement Core 2014.2.1 x001 x003 ©1993-2014 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
Median 2014.2.1 x001 x003 ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
Mezzotint 15.2.1, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Minimum 2014.2.1 x001 x003 ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
MMXCore Routines 2014.2.1 x001 x003 ©1990-2014 Adobe Systems Incorporated - from the file “MMXCore.plugin”
Mosaic Tiles 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Multiprocessor Support 2014.2.1 x001 x003 ©1990-2014 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
Neon Glow 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Note Paper 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
NTSC Colors 2014.2.1 x001 x003 ©1993-2014 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
Ocean Ripple 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
OpenEXR 15.2.1, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Paint Daubs 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Palette Knife 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Patchwork 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Paths to Illustrator 15.2.1, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
PCX 2014.2.1 x001 x003 ©1989-2014 Adobe Systems Incorporated - from the file “PCX.plugin”
Photocopy 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Photoshop 3D Engine 2014.2.1 x001 x003 ©2006-2014 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
Photoshop Touch CC 2014 (15.2.1.0) ©1993-2014 Adobe Systems Incorporated - from the file “PSDX.plugin”
Picture Package Filter 2014.2.1 x001 x003 ©1993-2014 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
Pinch 15.2.1, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Pixar 2014.2.1 x001 x003 ©1989-2014 Adobe Systems Incorporated - from the file “Pixar.plugin”
Plaster 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Plastic Wrap 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
PLY 2014.2.1 x001 x003 ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
PNG 15.2.1, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Pointillize 15.2.1, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Polar Coordinates 15.2.1, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Portable Bit Map 2014.2.1 x001 x003 ©1989-2014 Adobe Systems Incorporated - from the file “PBM.plugin”
Poster Edges 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
PRC 2014.2.1 x001 x003 ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
Radial Blur 15.2.1, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Radiance 2014.2.1 x001 x003 ©2003-2014 Adobe Systems Incorporated - from the file “Radiance.plugin”
Range 2014.2.1 x001 x003 ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
Read Watermark NO VERSION - from the file “DigiRead.plugin”
Render Color Lookup Grid 2014.2.1 x001 x003 �2012-2014 Adobe Systems Incorporated - from the file “Export3DLUT.plugin”
Reticulation 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Ripple 15.2.1, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Rough Pastels 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Save for Web 15.2.1, Copyright © 1999-2014 Adobe Systems Incorporated - from the file “Save for Web.plugin”
ScriptingSupport 15.2.1, Copyright © 2014 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
Shake Reduction 15.2.1, Copyright © 2014 Adobe Systems Incorporated - from the file “Shake Reduction.plugin”
Shear 15.2.1, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Skewness 2014.2.1 x001 x003 ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
Smart Blur 15.2.1, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Smudge Stick 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Solarize 2014.2.1 x001 x003 ©1993-2014 Adobe Systems Incorporated - from the file “Solarize.plugin”
Spatter 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Spherize 15.2.1, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Sponge 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Sprayed Strokes 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Stained Glass 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Stamp 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Standard Deviation 2014.2.1 x001 x003 ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
STL 2014.2.1 x001 x003 ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
Sumi-e 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Summation 2014.2.1 x001 x003 ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
Targa 15.2.1, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Texturizer 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Tiles 15.2.1, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Torn Edges 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Twirl 15.2.1, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
U3D 2014.2.1 x001 x003 ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
Underpainting 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Vanishing Point 15.2.1, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
Variance 2014.2.1 x001 x003 ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
Virtual Reality Modeling Language | VRML 2014.2.1 x001 x003 ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
Water Paper 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Watercolor 15.2.1, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Wave 15.2.1, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Wavefront|OBJ 2014.2.1 x001 x003 ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
Wind 15.2.1, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Wireless Bitmap 2014.2.1 x001 x003 ©1989-2014 Adobe Systems Incorporated - from the file “WBMP.plugin”
ZigZag 15.2.1, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Optional and third party plug-ins:
Imagenomic Plug-in Console 1.2 (c) 2010 Imagenomic, LLC. - from the file “ImagenomicPluginConsole.plugin”
Portraiture 2.3 © 2004-2010 Imagenomic, LLC - from the file “Portraiture.plugin”
Libraries
Adobe Color Themes
Installed TWAIN devices: NONE
3. Re: photos in photoshop opening as a collage of old photos along with fluorescent pink patches. Photos are completely distorted. photo attached
JJMack Nov 23, 2014 9:20 AM (in response to elandr5)I do not us a Mac do not know how to get the latest drivers for Mac. Try disabling yor GPU in Photoshop Preferences tab Performance and see it the image is correct.
