1 Reply Latest reply: Nov 24, 2014 9:48 PM by Silkrooster RSS
    Outline of images still remain after photomerge
    HakanNedjat Community Member
      Hi, I'm getting a strange outcome when trying to merge photos. Yes, the blend images is ticked but it doesn't seem to work. The photos are taken at the same exposure and lens corrections have been made.
      I think it's a memory issue but even after I cranked the below up to use 100% RAM and 8 cache levels it was still doing the same.
      If I try to blend any more than 5 images together photoshop just seems to give up half way through analysing the images and gets rid of all of them.
      I'm using a Lenova Yoga Pro 2 with the i7 2.4ghz processor and 8gb RAM.
      What could be causing this issue?
      Thanks for your help.
        • 1. Re: Outline of images still remain after photomerge
          Silkrooster Community Member
          Yeah, I think it is a memory issue. If you look at the maximum ram it shows you have less than 4GB. Odds are you have a bunch of other programs running that are taking up the extra ram that you need.
          You could test this theory, by reducing the resolution of the image to say 800x600 put all in a test folder, then photomerge just that folder. See if it is any better.
