1. Re: CS4 on win7 home prem 64bit
hans-g. Nov 23, 2014 12:36 AM (in response to bluesky)Hello bluesky,
on my computer (in order to edit or to compare files with newer versions) there I've often left older versions. In today's hard disk size should be no problem. BUT I do not let them run in a parallel mode simultaneously.
What affects the speed I did not have any negative experiences. Here in the forum, the recommendation is often one should empty the cache and something like this.
Hans-Günter
2. Re: CS4 on win7 home prem 64bit
bluesky Nov 23, 2014 12:44 AM (in response to hans-g.)Thanks Hans for your response. Maybe I wasn't clear enough.
My question was regarding the installation of CS4 on windows7 - will it work on the operating system with no problem? (The upgrading is on the operating system and not adobe programs)
3. Re: CS4 on win7 home prem 64bit
hans-g. Nov 23, 2014 12:47 AM (in response to bluesky)Hhm, sorry perhaps I for my part was not clear enough. With my post I would like to say "YES".
4. Re: CS4 on win7 home prem 64bit
bluesky Nov 23, 2014 1:03 AM (in response to hans-g.)Really? Even thought it says specifically on the box that its only good for XP and Vista(32b)?
5. Re: CS4 on win7 home prem 64bit
bluesky Nov 23, 2014 1:11 AM (in response to bluesky)Sorry for my doubts.. I just want to be sure that I will have the ability to use these programs on a new hard drive with windows7..
6. Re: CS4 on win7 home prem 64bit
hans-g. Nov 23, 2014 1:12 AM (in response to bluesky)Ok, if you are flatly refusing to test it, let it and leave it.
7. Re: CS4 on win7 home prem 64bit
bluesky Nov 23, 2014 1:21 AM (in response to hans-g.)Eventually i will have to install them..I just wanted to be sure that I will have the ability to use these programs on a new hard drive with windows7.
Thank you for your patients (regarding my doubts.. )
10. Re: CS4 on win7 home prem 64bit
hans-g. Nov 23, 2014 2:01 AM (in response to bluesky)You are welcome. Thanks for the little greenstar and all the best for you!
