1. Re: elements 10 will not import .xmp files from backup
MichelBParis Nov 23, 2014 9:25 AM (in response to geoffwheeler)If you did back up from the organizer, the xmp files were backed up and restored. I assume you did use another method?
2. Re: elements 10 will not import .xmp files from backup
geoffwheeler Nov 23, 2014 10:19 AM (in response to MichelBParis)The backup and restore were both done using the organiser. The icon appears in the organiser but no picture. Reconnect identifies 6460 missing files - i think they are all .xmp files. When I try to import one single file, elements says unrecognised file type.
3. Re: elements 10 will not import .xmp files from backup
MichelBParis Nov 23, 2014 10:33 AM (in response to geoffwheeler)geoffwheeler a écrit:
Ok.
If the icon appears in the organizer, what happens if you right click and choose 'update thumbnail'? Those thumbnails are not shown as missing with the '?' icon ?
It's normal that the thumbnails are not rebuilt immediately after a restore, it takes time to rebuild the cache.
When you run 'Reconnect', the file name with its extension is shown in the list of missing files. You'll never see an xmp file there.
Have a look at the contents of the backup folder. You can sort by extension in the explorer; you should see that you have got your xmp files.
If you get a message about missing files, it is always about image files, not xmp sidecar files.
4. Re: elements 10 will not import .xmp files from backup
geoffwheeler Nov 24, 2014 11:12 AM (in response to MichelBParis)Thanks for your help Michel.
It has been a long day. I tried your suggestion - right click and update thumbnail on individual pictures. Eventually Elements started to find the files. After many many reconnect attempts I have reduced the number of missing files from 6460 to 175!
So a very good result. I think the problem stems from faulty tracks on my backup hard drive.
But thanks to you I am nearly there.
Regards
Geoff Wheeler
Sent from my iPad
