1. Re: New CP8 Bug
RodWard Nov 23, 2014 3:21 PM (in response to jeanrouge)Is this audio added as on big clip spread over all slides, or as separate clip on each slide?
2. Re: New CP8 Bug
jeanrouge Nov 23, 2014 4:24 PM (in response to RodWard)No the audio is just imported to a single slide but the slide is after the quiz results.
The project is about 20 slides then there are 10 random question slides (from a pool of 34 questions). After that the results slide. Finally the slide in question that prompts the student to visit our website with 2 click areas redirecting to my website or iTunes. It has a 30 second audio file on it and every time you take the quiz after the second or third answer the audio starts running. The quiz keeps progressing fine but the audio of the final slide just starts running.
I had this problem on another project as well a while back (about a month ago) and ended up having to get rid of the audio on it all together, after trying everything possible.
3. Re: New CP8 Bug
nsukumar Nov 23, 2014 8:37 PM (in response to jeanrouge)Hi there,
Can you please specify your exact Captivate version?(Help>About adobe Captivate).
Nimmy Sukumaran.
4. Re: New CP8 Bug
RodWard Nov 23, 2014 9:22 PM (in response to jeanrouge)Find the audio clip in the Library, right click on it and look at Usage. You may find that it has become attached to some object on one of the slides in addition to the slide where you want it to play. If it hasn't, go through all the other clips in the Library to make sure there isn't another clip that is a copy of the audio and THAT clip has become attached to some object. If that doesn't help, then export the clip, change it's file name, delete the original clip in the project, and import the renamed clip.
5. Re: New CP8 Bug
jeanrouge Nov 24, 2014 1:40 AM (in response to RodWard)Tried all of that no matter what on the third question slide the audio starts.
Cp 8 V 8.0.1.242
6. Re: New CP8 Bug
nsukumar Nov 24, 2014 3:01 AM (in response to jeanrouge)Can you please share the .cptx file with us so that we can investigate the issue at our end. Please upload it to a shared workspace and send me the link to nsukumar@adobe.com.
Please share the following information along with the file.
1. Issue is seen on SWF output or on HTML5 output.
2. Browser version or Device details
3. Problem slide numbers
Nimmy Sukumaran.
