Show 2 replies
1. Re: stripy pattern
Ellis home Nov 23, 2014 4:13 PM (in response to alimami)If you select the image inside the graphic frame and click on the stroke panel, you'll see it's a sequence of 3 pt strokes with a 10% black tint. Just create the strokes, select them all and then Object>Paths>Make Compound Path and rotate them -45°. Create your graphic frame. Cut the Compound Path and Paste Into the graphic frame.
