1. Re: Help with motion text...
Jerry Klaimon Nov 23, 2014 5:12 AM (in response to DMH79)I use After Effects for title templates. Once done they can be brought into Pr and the text can be edited in either Ae or Pr.
3. Re: Help with motion text...
DMH79 Nov 23, 2014 2:15 PM (in response to Jerry Klaimon)Thanks Jerry. Any link to how to do this in AE? Also, in your sample, the first line is the closest as I'm ideally looking for it to be almost drawn out as if it were hand written. Elegantly using a calligraphy-type font. Really appreciate your response.
5. Re: Help with motion text...
Jerry Klaimon Nov 24, 2014 8:35 AM (in response to DMH79)In After Effects
1. Create new comp
2. Add type with the type tool
3. Add a text animation preset from the Effects and Presets menu
There are a lot of text animation presets. One category is Animate In (see attachment). The best way is to try a few presets to see if it gives you what you want. If you prefer to create your own preset, animate by adding key frames in the position element. Once you've got what you want, you can save it as a preset in the effects panel. This link will get you started. After Effects Help | Effects and animation presets overview
