1. Re: Exporting Layers to individual files
will.e.eckerslyke Oct 13, 2009 9:28 AM (in response to Dreadbydawn)Can't speak for Elements 8, but in Elements 6 you can do it like this:
- Rt-click the layer and choose Duplicate Layer
- In the ensuing pop-up dialog, click the Destination Document drop-down list, choose New
- Type a name of your choice for the new document
- Click OK.
A new document is created containing the chosen layer. Click File -> Save As to save it to disk in whatever format you prefer.
Hoe that helps you find the equivalent for your version of PSE.
2. Re: Exporting Layers to individual files
Dreadbydawn Oct 13, 2009 9:39 AM (in response to will.e.eckerslyke)I was hoping more for the ability to export all layers at once ala photoshop however this will do just fine.
Many thanks for your help
3. Re: Exporting Layers to individual files
will.e.eckerslyke Oct 13, 2009 9:53 AM (in response to Dreadbydawn)RE ...ability to export all layers at once...
Just tried this, works OK in PSE 6:
- Click the first layer
- Press and hold down the Ctrl key and click the other layers you're interested in exporting - they should now all be selected
- Rt-click any of the selected layers and select Duplicate Layers, then follow the remaining steps of my first attempt.
Edit: Just found that you can use Shift-Click as well, to select a number of adjacent layers in one go.
[I'm learning new tricks here as well :-) ]
4. Re: Exporting Layers to individual files
tko654321 Apr 14, 2012 8:55 AM (in response to Dreadbydawn)Thank you, thank you, thank you! This IS answered, because in Elements, there is no File/Scripts/Export Layers. The only way to do it is Duplicate a layer or layers and enter a New destination file.
5. Re: Exporting Layers to individual files
R_Kelly Apr 14, 2012 3:10 PM (in response to tko654321)If you have pse 6 through pse 10, then this export layers to files script should work:
https://acrobat.com/#d=blJVJ4ZFfR7dRg24q-mBbQ
To install:
1. download and unzip
2. right click on the script and choose copy
3. navigate to the elements scripts folder
example path: (windows and sustitute your version for 8.0)
C:\Program Files (x86)\Adobe\Photoshop Elements 8.0\Presets\Scripts
4. right click in a blank area and choose paste
5. start or restart elements and export layers to files should be listed under Files>Automation Tools
6. Re: Exporting Layers to individual files
dpyellow Nov 23, 2014 7:37 AM (in response to R_Kelly)Hi, sorry to gravedig, but does anyone have the script posted above by R_Kelly? It would be really useful if anyone could direct me to it, as the link just redirects to the Acrobat page. Thanks.
7. Re: Exporting Layers to individual files
MichelBParis Nov 23, 2014 9:41 AM (in response to dpyellow)R_Kelly will certainly come back when he is available.
It may be worth mentionning that the affordable add-on Elements+ provides a script for that.
9. Re: Exporting Layers to individual files
dpyellow Nov 23, 2014 5:26 PM (in response to R_Kelly)Thanks! This'll be really useful for my workflow!
