1. Re: AFTER EFFECTS PROBLEM WITH YOSEMIT
Lizlivlay Nov 23, 2014 2:49 PM (in response to juancho1234567890)I'd like to say that I have a similar problem. I had After Effects CS6 Already installed and on I updated to Yosemite, I got the above icon and can no longer open the application.
2. Re: AFTER EFFECTS PROBLEM WITH YOSEMIT
Andrew Yoole Nov 23, 2014 3:16 PM (in response to juancho1234567890)You need to provide much more information. What are the specs of your computer? Have you fully updated Yosemite to the current version? Are you using the Adobe CC Application Manager to install the software?
3. Re: AFTER EFFECTS PROBLEM WITH YOSEMIT
Dave LaRonde Nov 23, 2014 5:37 PM (in response to Andrew Yoole)....and have you ALSO updated your respective versions of AE recently to the ones designed to actually work with Yosemite?
4. Re: AFTER EFFECTS PROBLEM WITH YOSEMIT
Todd_Kopriva Nov 23, 2014 7:13 PM (in response to Dave LaRonde)Install the update:
5. Re: AFTER EFFECTS PROBLEM WITH YOSEMIT
juancho1234567890 Nov 23, 2014 7:22 PM (in response to juancho1234567890)The update that I have is OSX Yosemit 10.10.1, i already try to install the updates that the adobe page supply but the answer that I have when i try to open the program is that this " version of after effects does not work on yosemit os x", and teh version of after effects that i try to install is the After effects 12.0
6. Re: AFTER EFFECTS PROBLEM WITH YOSEMIT
Todd_Kopriva Nov 23, 2014 7:25 PM (in response to juancho1234567890)If you are trying to run After Effects C (12.0), you must install the update for After Effects CC (12.2.1): http://adobe.ly/DVA_updates
