1. Re: How do I create a final congratulations page with multi sco packager?
RodWard Nov 23, 2014 3:30 PM (in response to rocifier)That would normally be something you would set up in the LMS.
However, if that's not possible then I would probably set up a final module with sequence rules set so that it could only be opened once all other modules have been completed. You will need to be using SCORM 2004 for this. If the final module needs a score, add a scored button and tell the user to click this button to reach their certificate.
2. Re: How do I create a final congratulations page with multi sco packager?
rocifier Nov 23, 2014 3:44 PM (in response to RodWard)Hi thanks for your answer. Where can I find settings for the sequence rules that you mention?
3. Re: How do I create a final congratulations page with multi sco packager?
rocifier Nov 23, 2014 4:47 PM (in response to RodWard)I can see conditionals for total project points or total quiz points, but not total course points, since I suppose Captivate doesn't know I'm going to multi sco it. Is there a way to read in the current total course points obtained from SCORM?
4. Re: How do I create a final congratulations page with multi sco packager?
RodWard Nov 23, 2014 9:10 PM (in response to rocifier)That's not tracked in Captivate, only in the LMS. So you'd need to develop custom coding that interrogates the LMS to get the aggregated scoring information. Captivate isn't designed to do that.
As for the sequencing rules, that's also not something you can do within Captivate or the Multi-SCORM Packager tool. However, if you Google for information about SCORM sequencing rules there's plenty of information about the way to write them into the imsmanifest.xml file manually.
5. Re: How do I create a final congratulations page with multi sco packager?
rocifier Nov 23, 2014 10:09 PM (in response to RodWard)This is getting complex quickly. I'll try the manual sequence modifications. I see there is something called rollup rules. Is that what I want?
