Hello,
Is there a way that I can open context-sensitive web help in a new normal tab instead of having it as a pop-up so we can get rid of the pop up blocker?
Thank you,
You do this through the call. Which output are you creating? How you do this depends on the output and the method you're using for calling the help.
Kind regards,
Willam
Thanks for your reply, I am generating the output using the Web Help (Primary Layout) and then our developer is the one calling the pages.
So this is possible and is being set from the method calls, correct? -- I'll also ask our dev regarding this. Is there a snippet that should be added to do this so I can suggest on our dev?
Thank you,
This is set from the calls. Depending on precisely how your developers are calling the help, a small change in your output may be required.
You can give the following pages to your dev:
Kind regards,
Willam
