1. Re: How to change sequence settings without CC 7.1 update?
JSS1138 Oct 17, 2013 9:20 AM (in response to Sijimo9)There is no way to change sequence settings until the update. We haven't been given a hard release date for the update.
2. Re: How to change sequence settings without CC 7.1 update?
Sijimo9 Oct 21, 2013 12:38 AM (in response to JSS1138)Well, i've found out there is a way to edit seqence settings if you know how to use a WinRAR (to extract .prproj) and edit XML type files in notepad. So i have successfully finished my project days ago
3. Re: How to change sequence settings without CC 7.1 update?
Paolon Nov 20, 2014 9:54 AM (in response to Sijimo9)Sorry for bringing out that old threat, but i really need to know how you managed to edit the sequence settings! I am in that same nasty situation you have bee. I am on CS6.
Any help would be...extremely helpful!
THX
4. Re: How to change sequence settings without CC 7.1 update?
Sijimo9 Nov 23, 2014 6:11 AM (in response to Paolon)Hi Paolon!
You need to extract your .prproj using WinRAR to a text .prproj file, then use some text editor such as Notepad to search and replace sequence dimensions
For example find "1920" and replace it to "1280" if it looks like Īt belongs to a sequence definition.
I don't recall how it was called, maybe "VideoFrameRect" or something similar.
First create some very simple project to experiment with, and always make a backup copy in case something goes wrong
5. Re: How to change sequence settings without CC 7.1 update?
Paolon Nov 24, 2014 2:18 PM (in response to Sijimo9)Hi Sijimo9, thanks for your answer.
That was exactly what i have already tried. I have found all the "1280" line and changes to "1920".
I saved the file, opened in Premiere again and nothing changed...DAMN
