6 Replies Latest reply on Dec 1, 2014 8:01 PM by hasvi
    How to map para style by script
    hasvi
      Hi
      My indesign file has already some Group style, when I try to flow the XML file in Indesign that time same style of paragraph are not mapped with automatically. FYI
      Here 'TXT' style is already defined in 'Chapters' Group style (see Part A). After flowing again 'TXT' (see Part B) is coming in without mapping.
      Now I want to map the 'Part B' style with 'Part A' is this possible by script?
        • 1. Re: How to map para style by script
          Sajeev Sridharan Level 4
          Try this,
          app.findGrepPreferences = app.changeGrepPreferences = null;
          app.findGrepPreferences.appliedParagraphStyle = "TXT";
          app.changeGrepPreferences.appliedParagraphStyle = app.activeDocument.paragraphStyleGroups.item("Chapters").paragraphStyles.item("TXT");
          app.activeDocument.changeGrep();
          Vandy
          • 2. Re: How to map para style by script
            hasvi Level 1
            Hi vandy
            thanks, but if I want to add more style names in existing script means, how can I add the below styles
            TXI, H1, H2, EXT...
            thanks
            • 3. Re: Re: How to map para style by script
              BEGINNER_X Level 3
              Hi Hasvi,
              May the below code is useful, please test in your end.
              Thanks vandy...
              _mappingStyle("TXT", "Chapters", "TXT")
              _mappingStyle("TXT1", "Chapters", "TXT1")
              function _mappingStyle(findStyle, changeGroup, changeStyle)
                  app.findGrepPreferences.appliedParagraphStyle = findStyle;
                  app.changeGrepPreferences.appliedParagraphStyle = app.activeDocument.paragraphStyleGroups.item(changeGroup).paragraphStyles.item(changeStyle);
              Regards
              Siraj
              • 4. Re: How to map para style by script
                hasvi Level 1
                Hi
                I have used this code but its showing errors
                _mappingStyle("TXT", "Chapters", "Chapter_Title")
                _mappingStyle("TXT", "Chapter_Title")
                    app.changeGrepPreferences.appliedParagraphStyle = app.activeDocument.paragraphStyleGroups.item(changeGroup).paragraphStyles.item(changeStyl e);
                by hasvi
                • 5. Re: How to map para style by script
                  Chinnadk Level 4
                  try replacing the first line with this
                  and remove the second line.
                  Chinna
                  • 6. Re: How to map para style by script
                    hasvi Level 1
                    Hi chinna
                    thanks for your valuable information
                    by
                    hasvi
