Running msiexec.exe /i "install_flash_player_15_active_x.msi" on a Windows 7 x64 machine I receive an error message starting
"The installation package could not be opened......"
A damaged file is given as the main reason for this error which is why I have downloaded the file again from the following link http://www.adobe.com/products/flashplayer/distribution3.html
I still receive the same error.
Any suggestions?
That sounds about right; however, you should check the exact size in bytes (under Properties).
Just to make sure your download is not damaged, what is the downloaded file size? It should be 18,493,440 bytes.
Hi
I have tried downloading it several times now and it is always 18,063KB
I'll try to download it a again next week
I downloaded the file from the US server instead of the Australia server and this file works okay.
Not very impressed but at least this file isn't corrupt.
