Hi
I have this annoying problem with my Flash Player, I can't install it no matter what i browser it is in. When eg. I have to play a video from youtube, I can't use IE (Internet Explorer) to play it in, but in Googles Chrome and in Mozillas Firefox, there it works without any problem.
Another problem is also when I am going into www.adobe.com in IE, then it says - For the complete experience, please enable JavaScript in your browser. Thank you! , the script is active in the internet settings, I have check, but it is still not working.
If I uninstall Flash Player totally, and I would like to installed it again, I can't do it,, not matter what browser, it just stops, when iI try to install it . There is no problem installing or updating, Air, Shockwave. In this matter Flash Player will not cooperate at all, it will not let we installed it at all.
New I have tryed is that I installed the new flash player 16 demo, there were no problem in the installation, but it will still work in IE. It still says - For the complete experience, please enable JavaScript in your browser. Thank you! on www.adobe.com and it still not works on youtube.com. The script is active in the internet settings, I have check, but it is still not working.
I hope anymore is interresting in helping me in this annoying problem !
Regards
Peter
Something I forgot to tell, I don't know if it have anything to say. But after I updated java to 8 update 25, I think the problems begane !
My system is Windows Home - 64 bit
Do you have ActiveX Filtering enabled? Disable it.
Java shouldn't have any influence on Flash Player.
It have never been enabled while I have had this issue ! Just try again to install it again, still same problem. It is almost like it comes to some kind of a time out, and then it just stops try to install ! Stranges
If I download and would like to try again to install it agian, it says, after I have push the install buttom, that "Only a single instance of this application can run" it is almost like that the other installation is still running in the background !
