1. Re: There is a problem with Adobe Acrobat /Reader. If it is running ,please exit and try again.(0:104)
Bernd Alheit Aug 18, 2011 2:22 AM (in response to Ques.)Deinstall Adobe Reader and repair the installation of Adobe Acrobat.
2. Re: There is a problem with Adobe Acrobat /Reader. If it is running ,please exit and try again.(0:104)
swartz105 Sep 1, 2011 10:25 AM (in response to Bernd Alheit)I get the same error message. I'm able to open pdf's that are saved to my hard drive, but not directly from the internet. I've uninstalled and reinstalled many times. I've also tried to do a "repair", but nothing has seemed to work. Thanks...
3. Re: There is a problem with Adobe Acrobat /Reader. If it is running ,please exit and try again.(0:104)
RasmusTermo Sep 7, 2011 12:56 AM (in response to swartz105)I have some colleagues that suffers from the same problem...
Any suggestions to what is wrong. I tried to open a pdf in Internet Explorer locally stored on the computer, and that works fine?!? So it seems that something is only going wrong when opening a pdf directly from a link?!?
/Termo
4. Re: There is a problem with Adobe Acrobat /Reader. If it is running ,please exit and try again.(0:104)
MbdaLogicielsBureautiques Nov 10, 2011 6:10 AM (in response to Ques.)Hello,
Some of our users have experienced the same issue and we've found a solution : You need to go in the preferences of your Acrobat X Reader, go to the "General" settings, and uncheck "Activate the protected mode at startup" (not sure the translation is correct I don't use a US version).
After that, it will work fine... but your Reader X won't anymore be protected against PDF containing malicious code.
If someone has a better solution (one that would let the protection activated) I'm interested.
NB : This issue is only reproduced on a few of our computers, and our IT service can't reproduce it, so it's most likely an incompatibility with something special on the few PC impacted. But we don't know what...
5. Re: There is a problem with Adobe Acrobat /Reader. If it is running ,please exit and try again.(0:104)
larryfromgary Nov 14, 2011 5:16 PM (in response to MbdaLogicielsBureautiques)This worked and fixed the problem.
6. Re: There is a problem with Adobe Acrobat /Reader. If it is running ,please exit and try again.(0:104)
Yzorderrex Dec 5, 2011 5:51 AM (in response to Ques.)Simple, this error occures when you have two versions of Adobe Reader. Delete one of them and your problem should be solved at once.
7. Re: There is a problem with Adobe Acrobat /Reader. If it is running ,please exit and try again.(0:104)
rackhat Jan 13, 2012 7:13 PM (in response to Ques.)Here's what worked for me with Reader 10.2:
1) uninstall Reader
2) disable virus protection;
3) install Reader;
4) enable virus protection
8. Re: There is a problem with Adobe Acrobat /Reader. If it is running ,please exit and try again.(0:104)
MicheleDiaz Jan 17, 2012 4:43 PM (in response to Ques.)I have the same problem after Adobe X reader was installed on a server that already has Acrobat 7 Pro installed. Abobe X reader was uninstalled and an update to Acrobat 7 Pro was installed. The same error occurs. Any ideas?
9. Re: There is a problem with Adobe Acrobat /Reader. If it is running ,please exit and try again.(0:104)
Iliya9999 Jan 24, 2012 12:14 PM (in response to Ques.)I have the same problem: Acrobat Pro 7 resides on the computer and I can't install Reader X because of the error:
"There is a problem with Adobe Acrobat/Reader. If it is running, please exit and try again. (0:104)"
As nobody seems to be able to make this work, I guess I'll assume I must first uninstall Acrobat Pro 7. Depends on how bad you need Pro 7 and how bad you need Reader X, I suppose.
MicheleDiaz, did you ever get it to work???
10. Re: There is a problem with Adobe Acrobat /Reader. If it is running ,please exit and try again.(0:104)
chop_chop13 Jan 24, 2012 1:02 PM (in response to Iliya9999)Ditto here, I tried re-installing Adobe Reader but that didn't work either, and it appears in my add on, so, I'll keep checking her to see if someone knows an answer.
11. Re: There is a problem with Adobe Acrobat /Reader. If it is running ,please exit and try again.(0:104)
Iliya9999 Jan 24, 2012 2:16 PM (in response to chop_chop13)Hi,
MicheleDiaz, who had the same problem, replied to me. She said:
"To resolve my issue I had to disable the "Disable PDF in Browser" option.
This is located in Adobe Preferences (Edit, Preferences, Internet). With
that option off Acrobat opens the PDF."
I can't try it until I get home. If you can try it sooner, let me know.
12. Re: There is a problem with Adobe Acrobat /Reader. If it is running ,please exit and try again.(0:104)
chop_chop13 Jan 24, 2012 3:57 PM (in response to Iliya9999)Thanks, ,Iliya9999 , that worked!
Much appreciated
13. Re: There is a problem with Adobe Acrobat /Reader. If it is running ,please exit and try again.(0:104)
Iliya9999 Jan 24, 2012 5:36 PM (in response to Ques.)OK, I got it to work. First I opened Adobe Acrobat 7.0 Professional. Then I followd MicheleDiaz's instructions. That eliminated the ERROR 0:104, but then I got the "Failed to Initialize" error. I downloaded Reader X from: http://get.adobe.com/de/reader/enterprise/ The instructions are in German, but of course it's obvious, and THAT worked!
Finally. What a pain.
14. Re: There is a problem with Adobe Acrobat /Reader. If it is running ,please exit and try again.(0:104)
chop_chop13 Jan 24, 2012 5:43 PM (in response to Iliya9999)I totally agree. When something like this happens I spent hours of productive time fooling around trying to fix it! On the upside, it is free software, so I’m thankful to have it because it does the job when its working right.
15. Re: There is a problem with Adobe Acrobat /Reader. If it is running ,please exit and try again.(0:104)
srp1956 Feb 6, 2012 11:54 AM (in response to Iliya9999)Resolved issue. Disabled 'Open PDF in Browser' option in Adobe Acrobat 7 Pro. Enable or disable same option in Acrobat Reader 10 depending on preference. Thanks for the help.
16. Re: There is a problem with Adobe Acrobat /Reader. If it is running ,please exit and try again.(0:104)
ym1310 Feb 7, 2012 1:05 PM (in response to Ques.)Resolved 0:104 problem in Adobe Acrobat Standard 7.1.0. Unticked "Display PDF in browser" option as above and now displays PDFs in Explorer 8. Thanks very much for your help.
17. Re: There is a problem with Adobe Acrobat /Reader. If it is running ,please exit and try again.(0:104)
Suej Radar Oct 8, 2012 2:42 AM (in response to Iliya9999)Thanks Iliya9999
Your solution going into the Internet preferences worked for me too :-)
18. Re: There is a problem with Adobe Acrobat /Reader. If it is running ,please exit and try again.(0:104)
PaddPro Jan 9, 2013 6:46 PM (in response to Ques.)Guess this is a sameohsameoh. Had problem also; came here, did the UNcheck Display PDF in Browser and error goeth away...hooray. CS6 Acrobat BTW. My thanks also since that is quite a productivity inhibiting error.
19. Re: There is a problem with Adobe Acrobat /Reader. If it is running ,please exit and try again.(0:104)
shellierock2 Feb 15, 2013 8:08 AM (in response to Ques.)I have tried multiple things, changing security settings, associating Reader instead of Adobe Acrobat 7, etc... finally found an answer on the Adobe site. Unfortunately its hidden and took me an hour to find so I thought I'd share because it finally allowed me to view PDFS from links on-line. The source is: http://helpx.adobe.com/acrobat/using/display-pdf-browser-acrobat-xi.html.
Open Internet Explorer, and choose Tools > Manage Add-ons.
Under Add-on Types, select Toolbars And Extensions.In the Show menu, select All Add-ons.
Select All Add-ons from the Show menu in the Manage Add-ons dialog box.In the list of add-ons, select Adobe PDF Reader.Note: If you do not see the Adobe PDF Reader add-on, try the other options on the menu. For example, on some systems, the add-on appears when you select Run Without Permission.
Click the Enable or Disable button (it toggles depending on the status of the selected add-on):Enable sets the Adobe PDF Reader add-on to open PDFs in the browser.
Disable turns off the add-on so it does not open PDFs in the browser.
GOOD LUCK!!
20. Re: There is a problem with Adobe Acrobat /Reader. If it is running ,please exit and try again.(0:104)
gaby4924 Dec 1, 2014 11:57 AM (in response to shellierock2)Thanks!!!! I did what you say and it worked!!!
