Hi, thanks for taking my question. In IE11, in online help created using RH7 HTML, the TOC and Search don't appear, an issue that I know has appeared on the forum before. From a search on this forum, I see that a fix applies to RH10. (Sorry, I downloaded the files, but now can't find the post with the fix. Zip is IE11Fix_RH10.zip.) Will that fix work backwards to RH 7? Or is RH 7 completely incompatible with IIE11?
Apologies if this has been answered.
RH7 – pretty sure you’re completely out of luck.
That fix is not backwards compatible. I'm afraid that IE 11 is not supported for RH7. I have backported a solution to RH9, but RH7 is just too old with too many issues to even try a fix.
The best solution would be to upgrade.
Kind regards,
Willam
Thanks. An upgrade isn't possible. In brief, RH 7 is on life support until we can move to a new CMS. Think good thoughts.
Thanks. I was hoping for a miracle!
