I have a new laptop, and have installed TechCommunicationSuite_4_WWEFDJ, which includes RH10. I mapped RH to source control (Team Foundation Server MSSCCI Provider), and have successfully been able to check-in/check-out files.
When I generate WebHelp, below is what displays in the Output View, and then I get an error prompt that RH is not working and to close it, find an online solution, etc.
I must be missing a dll or something in my new laptop. Everything was working fine on the old one. Does anyone know how to resolve this?
Output View
Starting compilation...
WebHelp preprocessor 10.0.0.287
Clearing output folder...
Compiling C:\FuelsManager Help\Web Application\Cirrus\index.htm... note: the output folder is local only; not mapped to source control
Preparing to create WebHelp...
Preparing files for WebHelp...
This is what I got from the error details:
Problem signature:
Problem Event Name: BEX
Application Name: RoboHTML.exe
Application Version: 10.0.1.292
Application Timestamp: 51493787
Fault Module Name: RHUtils.dll
Fault Module Version: 10.0.0.287
Fault Module Timestamp: 4ff35385
Exception Offset: 000643af
Exception Code: c0000409
Exception Data: 00000000
OS Version: 6.1.7601.2.1.0.256.4
Locale ID: 1033
Additional Information 1:
so not sure why I can't post the 9 1 4 3 number...
Additional Information 2: 9 1 4 3a6597780609423fd68bf08ad2a3e
Additional Information 3: 4 0 1 f
Additional Information 4: 4 0 1 f170992d76279abe942aefaa0e0f2
The details you are giving would only be of meaning to Adobe. Is this happening with one project or any project including a newly created project?
Thanks for the quick reply.
I tried to generate WebHelp for one of my older projects, but did not connect it to source control, and it generated the WebHelp.
I did the same on the new project, did not connect it to source control, it still crashed.
What’s happening if you try one of the sample projects? How about letting the problem project generate in the project’s \!SSL!\ folder? How long are your path lengths? That might have an impact on the process too (hint: shorter is better)
I'm not sure what the sample projects are.
The output path is on the same level as the !SSL! folder: C:\FuelsManager Help\Web Application\Cirrus
The sample projects are shipped with your copy of RH (you can open them from the Starter screen or in C:\Program Files (x86)\Adobe\Adobe RoboHelp 10\RoboHTML\Samples\en_US\ - in my case). Try one & see if it bombs.
If it doesn’t, try generating your problem project to the \!SSL!\ default folder.
If you are still stuck & can share your project, I’d be willing to have a look at it. Contact me via PM for e-mail addresses.
I was able to generate one of the samples: WebHelp - Location Based
I'll have to get my manager's approval to share the project. I'll get back with you.
Appreciate all your help!
Ok, it crashes for me too – I tried trashing half the topics & retrying it, but it still kept crashing. So I created a fresh project and started importing htm topics from the damaged project in, one letter at a time. When I got to the C’s, (test compiling each letter), I saw that there was a couple of odd looking topics - cshdat_robohelp.htm & cshdat_webhelp.htm. When I looked at them, they appear to be output files. I think that’s your problem here – you seem to have source project content mixed up with output content – the two should never mix. That’s why there’s am \!SSL!\ folder for creating the webhelp in.
There were a couple of files missing when I mapped the files in source control to the new laptop. And I couldn't find the source file anywhere, so I figured I'd just copy them from the output files.
I deleted the files you mentioned from the source folder, but it's still crashing. Now the trick is to identify those files.
Is there any way for me to quickly identify those files?
Thanks for all your help!
Nope – source project files are completely different than output files. RH takes the source ones & changes them to make them output files. You should have a backup of the project someplace, right? If you don’t, then you could always reverse engineer a project out of the source files – see Willam’s web site (http://www.wvanweelden.eu/product-category/recovery-script) for a solution.
It's gonna be a long one!
Thanks for your help! Appreciate it!
Did your IT not take an image of the old machine to use on your new one? Or at least back everything up first?
The backup machine was the server which I mapped to the new laptop.
I do have a copy of the source files in my external drive, but they're a year old. So much has changed since then.
So now, I'm comparing both source files to see if there's anything amiss.
One question... When I copied an output HTML file into the source folder, I noticed that RoboHelp put red boxes at the top of the page, which I understood were the breadcrumbs in the output files. I deleted those red boxes.
Would that trick RoboHelp into thinking that the output files are now the original source files?
Ok, so now I'm comparing both source files, and I'm seeing the output files you mentioned earlier (cshdat_robohelp.htm & cshdat_webhelp.htm) in the old project.
Hi there
Those red boxes are just the tip of the iceberg.
Depending on the recipe settings, all sorts of different javascript references and links are added to the topics. Just like a baked chocolate chip cookie is very different from the little ball of dough it began as, the output topics are really different animals than their source counterparts.
Cheers... Rick
When you use a source control system with RH, not everything is committed to SC; you still maintain local files that need to be periodically backed up.
Hmmmm I was told different by one of our developers. He said I shouldn't have to worry coz everything is in the server.
I should have known better and backed up my files.
Lesson learned the hard way.
I'll try compiling each letter like you did, Jeff. Will be easier for me to track the files.
I'm not sure if I can do the reverse engineer, because I have about 6 different output files for different customers. And conditional build tags have been applied to the project files.
1] It should be easy enough in your existing project to open each topic and look for red squares.
2] No reverse engineering will not work nicely for you as each CHM will have different content.
What your developer did not understand is that unlike ordinary HTML files, source topics also contain PIs (Processing Instructions) that are required to enable you to produce different output topics from the same source file.
Wherever I have worked I have always kept a copy of my projects on my own external drive. Trust no one!
Thanks for the advice Peter! I'll definitely backup my projects in my external drive.
Ok. I've given much thought on how this project started crashing.
So, after I mapped the new laptop to source control, that's when I noticed the missing project files (had x next to it) and broken links. Not a lot. About 6 or 7, max 10.
I couldn't find the source files anywhere, so I copied those files from the output folder.
I have done this same process in the old laptop when source control was moved to a different server.
When I first noticed those red boxes, I did not delete them.
I generated the help, and noticed two breadcrumbs. That's when I realized the red boxes were breadcrumbs, so I deleted all those.
Two things:
So now I'm not so sure if copying the project output files over to the source files is causing the crash.
