1. Re: Mouse pointer not following new path
Captiv8r Dec 1, 2014 12:30 PM (in response to TXBertLady)Hi there
Can you perhaps share some screen captures of the two slides in question along with the timelines?
Cheers... Rick
2. Re: Mouse pointer not following new path
TXBertLady Dec 1, 2014 1:20 PM (in response to Captiv8r)The image on the left shows where the mouse pointer is placed (it is invisible) on the slide. The image on the right shows the correct path starting from the previous slide (slide on left), However, the mouse does not move along the path, it shows up in this slide resting on the login button. I did publish it to make sure it is NOT working. What am I missing here? I really appreciate your input.
3. Re: Mouse pointer not following new path
Captiv8r Dec 1, 2014 2:02 PM (in response to TXBertLady)Thanks for the images.
Does anything change if you click the mouse on the timeline (clicking the shaded yellow section) and drag it to the top of the timeline?
Cheers... Rick
4. Re: Mouse pointer not following new path
TXBertLady Dec 1, 2014 2:23 PM (in response to Captiv8r)I just tried that and nothing changes. It is a mystery!
5. Re: Mouse pointer not following new path
Captiv8r Dec 1, 2014 3:20 PM (in response to TXBertLady)If it were me, I'd opt for what I call a "sanity check".
I'd adjust the timing on the slide to be longer and adjust the mouse movement so it's substantially longer. This should produce a "slow motion" effect for the mouse and slow it down. If something is really flaky, you won't see the mouse at all. But if you do see the movement, you know it's likely a timing issue.
Cheers... Rick
6. Re: Mouse pointer not following new path
TXBertLady Dec 1, 2014 3:26 PM (in response to Captiv8r)I will give it a try. Thank you so much for your time.
