2. Re: Virtual adobe printer
mister75 Nov 28, 2014 8:42 AM (in response to kglad)Nope
Forgot to say
I am having Windows 7 pro 64bit. -
3. Re: Virtual adobe printer
kglad Nov 28, 2014 8:52 AM (in response to mister75)did you follow the manual install directions?
4. Re: Virtual adobe printer
mister75 Nov 28, 2014 9:02 AM (in response to kglad)yes but under
C:\Program Files (x86)\Adobe\Acrobat 7.0\Acrobatthere is no subfolder xtras
5. Re: Virtual adobe printer
kglad Nov 28, 2014 9:11 AM (in response to mister75)probably time for an upgrade then. or use doPDF.
6. Re: Virtual adobe printer
mister75 Nov 28, 2014 9:29 AM (in response to kglad)I am using pdf24
Got acrobat 7,0 from the webpage of adobe as it is out of time xD -
7. Re: Virtual adobe printer
kglad Nov 28, 2014 11:07 AM (in response to mister75)i don't know much about pdf24 but it looks like it has very limited print to pdf capabilites. again, check doPDF if you can't get acrobat's print to pdf to work.
8. Re: Virtual adobe printer
Dov Isaacs Dec 2, 2014 10:42 AM (in response to mister75)The simple answer is that Acrobat 7 does not support any 64-bit version of Windows. There are no workarounds. Acrobat 8.1 (an update to Acrobat 8.0) was the first version to support 64-bit Windows and primarily, the area of support that was added was that of the AdobePDF PostScript printer driver instance, which is what you are referring to as the “Virtual Adobe Printer.”
The current version of Acrobat is 11.0.9. Previous versions are no longer available for licensing.
- Dov
