I purchased a new laptop with Windows 8.1. I had a previous latop that had been upgraded to Windows 8.1 and ran CF10 perfectly fine. I made sure the necessary IIS modules were installed for CF. I installed CF11 using the "Run as administrator" option, just to be on safe side. Everything appeared to go smoothly and no hiccups occured. However, when I click to go CF admin page, I received an Error 500. I've made sure permissions on the folders are correct and allow for the IIS_USR a even IUSR. Any help would be greatly appreciated. I am sort of at a loss here.
The detailed information is as follows:
Module | IsapiModule |
Notification | ExecuteRequestHandler |
Handler | cfmHandler |
Error Code | 0x800700c1 |
Requested URL | http://127.0.0.1:80/CFIDE/administrator/index.cfm |
Physical Path | D:\ColdFusion11\cfusion\wwwroot\CFIDE\administrator\index.cfm |
Logon Method | Anonymous |
Logon User | Anonymous |
Solution as Anit Kumar says, I must have installed the wrong bit version thinking it to be 64bit...
We found this out by setting up the internal CF webserver (on port 8500) and looking into the CF Administrator in that way.
- stop the CF Application service
- enable built in webserver in xml config file
- Command prompt Run as Administrator
- In CMD navigate to Coldfusion11/cfusion/bin/ and launch command : 'coldfusion -start -console' -> CF will be started from CMD
- in browser navigate to localhos
...Copy link to clipboard
For some reason using the web connector tool, I can remove the connections, add them again this time allowing for 32bit and it works, but agonizingly slow. If i try to go back and remove the 32bit connectors and set it up again as 64bit, it throws the error 500 again. This is frustrating.
ColdFusion and IIS both should have same bitness. If CF is installed in 64-bit mode, then change the App pool (Enable 32 bit applications” set to false) under Advanced Settings. Remove the connector and recreate it.
Once done, launch command prompt as administrator and try iisreset command. Now you can test your site/CF Admin.
Anit Kumar
I'm experiencing the same problem as OP and I wonder if the proposed fix worked? It tried to implement the solution but to no avail.
I'm working with a fresh install of Windows 8.1 x64 Enterprise with IIS 8.5. I verified all installed features of IIS as following :
In IIS Management console I verified all access by adding a specific connection user. (the local administrator account)
The default application pool is set to x64 only (= disabled x32 support in Advance settings of Application Pool Management)
The error message received when browsing the http://localhost/CFIDE/Administrator/ :
I cannot seem to resole this issue, but is it related to the x64 version of Windows?
Anyway, I've been searching the web for a few days now and I did not find any solution yet.
Any thoughts how to resolve this, short from installing Windows 7 and going from there?
Thanks for reading,
Regards Bert.
Can you ensure that the cfm handlers are added at the Serevr/Site level?
Anit Kumar
Please see Print-screen below:
They appear to be all there...
They all look fine. It seems like a permission issue. Can you check the permission on wsconfig folder?
Anit Kumar
Hi Anit Kumar,
It seems fine, see print-screen :
Can you access ColdFusion with the built-in port?
Anit Kumar
How would I go about to access CF in that way? I do not seem to be able to find a clue how to do such a thing.
If you refer to locahost:8500 port, I can say I just tested that and as expected it did not work. I never created a site on that port and I made CF install mappings on the IIS directly.
Ok, I'll send my case through via that email.
Thanks for taking the time to look into this!
Regards Bert.
We figured out it to be an application pool issue. CF was running in 32-bit and IIS was running in 64-bit mode. We changed the Application Pool bitness to 32-bit and issue resolved.
Anit Kumar
- in browser navigate to localhost:8500/CFIDE/Administrator/ and login.
- goto Settings Summary and check parameter 'Java VM Name'; if it does NOT contain something like 'x64' it is a 32 bit install!
Then we enabled 32bit support in IIS management console via ApplicationPool -> Advanced Settings and voila it worked!
Next I'll download and install the correct version I intended all along! 😉
Once again thanks for the support!
Regards Bert.
Attached is a screen shot for my future reference and others. I found that it's best to just set the Application Pool Defaults by clicking on "Set Application Pool Defaults" when the Application Pools node is selected. Once the dialog for the defaults is open choose the correct Bitness for Enable 32-bit Applications. This way all application pools that get created retain the correct bitness and avoid this super annoying error. Not sure why 32Bit apps is the default on an x64 system, but I'm sure there is more going on than I care to figure out at this point.
2 hours blaming it on the CF 11 Update 2 / CF 10 Update 14 bug that mangles the Visual C++ Distribution. If the bitness matching issue isn't your problem check out this other post on how to manually install updates.
