Hi All,
I am very new in ColdBox framework but have a good experience in ColdFusion.
In browser I am firing a url like below.
http://abc.xyz.dev.local/index.cfm?event=event.userLists&user_id=1463613.
Here the event handler named "event" is pointing to the path - \handlers\pdt\real\ldr\ldr_nm\ldr_portal\ldr_agt\event.cfc. My question here is how ColdBox framework identifies this cfc file(\handlers\pdt\real\ldr\ldr_nm\ldr_portal\ldr_agt\event.cfc). I know there is some config file where we can provide this handlerspath . But in my application (where I am working) I can see this file but it has been configured as just "handlers" instead of what I am expecting like "\handlers\pdt\real\ldr\ldr_nm\ldr_portal\ldr_agt\event.cfc". Please correct me if I am wrong as I dont have much knowledge about this framework
Is there any other configuration file or any more set up can be done to map this handler to.
Your timely help is well appreciated.
Thanks in advance
You might be better served posting to the ColdBox Google Group. Be patient if you don't get an immediate response or see your post immediately - first posts are moderated for new members.
-Carl V.
Yes I did the same as no one is responding to this thread for the last 3-4 days.
Thanks Carl... at least you responded
Abdul,
My guess is that few ColdBox users frequent these forums. Since ColdFusion developers who are using a full-stack MVC framework (like ColdBox) generally fall into the "intermediate" to "advanced" camps, they don't get much value from the level of peer assistance typically available on these forums. You'll see them more on the ColdBox Google Group or over on StackOverflow. So I'm not surprised no one has responded directly to your issue here.
I hope you get the help you need on the ColdBox Google Group.
Cheers!
-Carl V.
