Hello,
I'm currently using RoboHelp HTML 11 (11.0.3.268) and have created a couple web help projects using the Responsive HTML5 layout (since the help files are for applications designed to run on iOS devices). I would like to provide an easy way for users to print both individual topics as well as collections of topics (a group of sub-topics under one TOC book for example). However, the only print options I can find are for printing individual topics via the right-click menu either within a given topic ('Print') or from the Search Results or Index screens ('Print Target').
Does anyone know of a way to add a print control within RoboHelp that would make it easier for users to print single topics or a TOC book and all it's subtopics, much the same way they are able to in .CHM files?
Thanks in advance for any help or guidance you can provide.
Sincerely,
Dave
There's no way to simply print multiple topics. The easiest solution is probably to create a PDF output and link that in your web output.
Kind regards,
Willam
